Tested this via automix for 3 hours yesterday and no issues. Then 15 mins into playing my gig and again a fully loaded cached song stops playing for no reason. This has been happening for the last month. Thankfully I had another system to play on as feared I would have problems again after my last gig was affected the same way.
I no longer have any faith in this software after using it for over a year. Back to Traktor and offline tracks. Too embarrassing to have music stopping on you in the middle of a gig.
PS my internet connction was fine and it was set to default quality.
Any update from Algoriddim on when they are going to fix the crashing problems? SImply can no longer use this software for more than a 30 mins without songs freezing even though fully loaded.
David, sorry you’ve been having trouble. We’ve addressed a number of issues in previous updates regarding streaming. Some might be network related that we have no control over. That being said, can you please let me know with which version of djay (Pro) you are experiencing which issue with specifically? I assume you are on the latest version. Looking forward to hearing from you.
Algoriddim team… are you aware of this? working in a solution?
Sorry for saying this, but… this is top priority for sure and for us, users working and trusting your software every weekend!! I feel so insecure to use it now… this kind of problems can’t append in a PRO software. Spotify oficial and trust integration was the top feature to go with Djay… I’ve been working three years without any problem… but know… I can’t trust it no more…
Please, say us something… that you are working in this issue…
This is very urgent,
Maybe if we be habble to access spotify offline playlist, that’s ok, but, I understand apple ecosystem don’t allow this inter app connection.
I agree! But I use the iPad version, I think this problem with Djay was something that spotify has change as a service. Let’s hope Algoriddim solve this fast… I too have a bunch of weddings to make
I use it that way too My phone with off line spotify songs when needed and a open channel in the mixer, but we really need this problem to be solved .)
