Stuttering and freezing after using Neural Mix + Mixon 8 – Anyone Else?
Hi everyone,
Could you test something for me?
I’m reaching out to see if others like you have experienced similar issues with stuttering, freezing, or tracks not starting properly after using Neural Mix in Algoriddim DJay.
I will show it to you. In my case, I have toggled Neural Mix to the EQ knobs. but I’m not sure if this is related, but the issues also persist if the Neural Mix settings aren’t fully reset before loading a new track.
:fast_forward: You can see for yourself(*) in this video the problems I encounter. Like you can see there also seems to be a 100% correlation between these problems and quickly scrolling through a track.
(*) E.g. on5m02, 5m32 and 8 min in the video
If you seem to have this problem as well, could you please share your experience?
Specifically:
  • What hardware are you using?
  • Does the issue occur only after you ‘activated’ Neural Mix in a track or also without?
  • Have you noticed any patterns or specific triggers?
Your feedback would be incredibly helpful, both for troubleshooting and for providing the developers with more insights to resolve this.
Thanks in advance for your input! :folded_hands:
Best regards,
DJ_Big_Blender
For reference I’ll add the original case:
And
7 posts were merged into an existing topic: Issue with track stuttering and freezing when scrolling quickly through it
Hi @DJ_Big_Blender,
Thank you for sharing this issue again in a different capacity.
We have merged this thread into your original thread on the same topic for easier review and community management.
I will be closing this thread. Thank you.
