Just purchased the Pioneer NXS2 set and would love to see them supported (native HID) by Djay Pro. Hopefully with full scrolling waveform support
When??? This is making my gigs rather frustrating not having the mapping options.
The newly released djay Pro 1.4.3 for Mac is Pioneer DJ certified and comes with native support for the CDJ-2000NXS2 and CDJ-TOUR1 via USB-HID along with DJM-900NXS2 and DJM-TOUR1.
Additionally, using LAN Link (Pro DJ Link) you can connect up to four CDJ-2000NXS2 players with your DJM-900NXS2 mixer via LAN cables, then simply use a single USB cable to connect their Mac to the mixer and everything syncs seamlessly (same for CDJ-TOUR1 players and DJM-TOUR1).
Enjoy!
Yes you can but the topic of this thread is the CDJ-2000NXS2. Please not the bottom of the product page https://www.algoriddim.com/hardware
Very nicely done. I am gad you went through the proper channels with the Pioneer DJ certification. Furthermore congrats on being the FIRST to be certifed for the Tour1 players.
we know about the user demand of the mapping of the CDJ-2000NXS2.
Stay tuned for updates.
Hey there,
sorry for the delay. We are working at a mapping and will provide the mapping as fast as possible.
Cheers,Lukas E.
Hey Oscar Flores,
be assured that the support of the CDJ-2000NXS2 has a high priority for us.
We hope to be able to provide an update with an extension of our supported mappings as soon as possible.
Any updates to this?
how are things going with this?
Yes please… Waiting and keen. Please don’t make us wait too long!
Here it is again: https://www.dropbox.com/s/djn2ujw1mrz…
hi hi,
i also still waiting desperately for the mapping… i try to figure out, using the editor … only works for one player
please help asp
could u please share ur mapping file for cdj-2000nx2 again
thnxxx a lot
thanxxx a lot
I have worked up a quick midi file that works the basics through the midi controls. Pls dont post critical comment as its only a temporary fix while the support team do the pro job, but it took my a few hours and works (ish) so might get you working in the short term:
Upload the file - its only midi - nothing clever. Install into the right folder for midi mapping.
connect to DJ Pro via USB as normal then click and hold menu button and select midi channel. The midi channel corresponds to the deck number. i.e. midi channel 1 is deck 1, midi channel 2 is deck 2 etc up to 4 decks.
Download link: https://www.dropbox.com/s/rbc1debvwsf…
Dont forget to also connect your Mac to the mixer, then go into DJ Pro preferences and select the external output, linking the right channels on the output from each deck to the channels on the mixer.
I hope this works for you… like me waiting for the real thing!
Here goes again: https://www.dropbox.com/s/4fxc5cdltz1…
The link has expired, do you still have this and if so, would you be so kind to share again?
Thanks so much
Can I get that one more time from you, @Paul?
Still no support guys? It’s been 8 months…
