It does, ive tried and started to map in on Mac. i’d guess its a 2 hour work to fully map it, ill give it a go once i finish with other project.
From what I tried (few years ago before giving up), the turntables and LEDs are trickier to map. Buttons and sliders are quite easy.
FYI, VirtualDJ works best with the first USB (A) or with USB (B) set in “vendor” mode.
Also cc @Omar_Becerra
I am not able to upload the XML file with VDJ mappings, but if it helps:
<?xml version="1.0" encoding="UTF-8"?>
<mapper device="ROL707M" author="Atomix Productions" version="850" date="2023-07-07">
<info>http://www.virtualdj.com/manuals/hardware/roland/dj707m.html</info>
<map value="ONINIT" action="fake_master on & fake_filter on & fake_hp on & deck all pad_pages 1" />
<map value="ONEXIT" action="fake_master off & fake_filter off & fake_hp off" />
<map value="SHIFT" action="shift" />
<map value="DNC_KEY_DECK" action="get_key 'roland'" />
<map value="DNC_USB_A_CON" action="set '$rol707_usbab' 1" />
<map value="DNC_USB_B_CON" action="set '$rol707_usbab' 2" />
<map value="DNC_USB_A" action="var '$rol707_usbab' 2 ? mute on : var '$rol707_usbab' 1 ? mute off : nothing" />
<map value="DNC_USB_B" action="var '$rol707_usbab' 2 ? mute off : var '$rol707_usbab' 1 ? mute on : nothing" />
<map value="DNC_MODE" action="blink 200ms" />
<map value="DNC_TRS_START" action="set '$trs_start' 1" />
<map value="DNC_TRS_STOP" action="set '$trs_start' 0" />
<map value="DNC_TRS_SYNC" action="set '$trs_sync' 1" />
<map value="DNC_SHIFT_TRS_SYNC" action="set '$trs_sync' 0" />
<map value="DNC_LED_TRS_BEATNUM 1" action="var '$trs_start' ? var '$trs_sync' ? master_beat_num 1" />
<map value="DNC_LED_TRS_BEATNUM 2" action="var '$trs_start' ? var '$trs_sync' ? master_beat_num 2" />
<map value="DNC_LED_TRS_BEATNUM 3" action="var '$trs_start' ? var '$trs_sync' ? master_beat_num 3" />
<map value="DNC_LED_TRS_BEATNUM 4" action="var '$trs_start' ? var '$trs_sync' ? master_beat_num 4" />
<map value="DNC_LED_TRS_SYNC" action="var '$trs_sync' ? true : false" />
<map value="DNC_LED_TRS_SYNC_OFF" action="var '$trs_sync' ? false : true" />
<map value="DNC_LCD_BPM" action="load_pulse ? get_bpm & param_multiply 10 & param_cast 'integer'" />
<map value="DNC_CLEAR_LCD" action="not load_pulse" />
<map value="DNC_LCD_BPM_TRS" action="var '$trs_sync' ? masterbpm & param_multiply 10 & param_cast 'integer'" />
<map value="PLAY" action="pioneer_play" />
<map value="CUE" action="pioneer_cue" />
<map value="SHIFT_CUE" action="goto_start" />
<map value="SHIFT_PLAY" action="play_stutter" />
<map value="SYNC" action="custom_button 4" />
<map value="SHIFT_SYNC" action="masterdeck" />
<map value="SHIFT_LED_SYNC" action="masterdeck" />
<map value="LED_SYNC" action="is_sync" />
<map value="JOG_TOUCH" action="touchwheel_touch" />
<map value="JOG" action="touchwheel" />
<map value="SHIFT_JOG_TOUCH" action="touchwheel_touch 'search'" />
<map value="SHIFT_JOG" action="touchwheel 'search'" />
<map value="DECKC" action="deck 3 leftdeck" />
<map value="DECKA" action="deck 1 leftdeck" />
<map value="DECKD" action="deck 4 rightdeck" />
<map value="DECKB" action="deck 2 rightdeck" />
<map value="SHIFT_VINYL" action="vinyl_mode" />
<map value="RANGE" action="pitch_range +1" />
<map value="SHIFT_RANGE" action="key_lock" />
<map value="PITCH" action="pitch 'dual'" />
<map value="BROWSE" action="browser_scroll" />
<map value="LOAD" action="browser_window 'folders' ? browser_window 'songs' : load" />
<map value="BACK" action="browser_folder" />
<map value="SHIFT_VIEW" action="skin_panelgroup 'mixer' +1" />
<map value="SHIFT_AREA" action="browser_window +1" />
<map value="ADD_PREPARE" action="playlist_add" />
<map value="SHIFT_ADD_PREPARE" action="sideview +1" />
<map value="VOLUME" action="volume" />
<map value="EQ_LOW" action="eq_low" />
<map value="EQ_MID" action="eq_mid" />
<map value="EQ_HIGH" action="eq_high" />
<map value="GAIN" action="gain" />
<map value="PFL" action="pfl" />
<map value="FILTER" action="filter" />
<map value="VU_METER" action="get_level" />
<map value="LINE_CH" action="param_bigger 0.4 ? linein on : linein off" />
<map value="CROSSFADER" action="crossfader" />
<map value="CF_ASSIGN_LEFT" action="cross_assign 'left'" />
<map value="CF_ASSIGN_THRU" action="cross_assign 'thru'" />
<map value="CF_ASSIGN_RIGHT" action="cross_assign 'right'" />
<map value="CF_CURVE" action="crossfader_curve" />
<map value="MASTER_VOLUME" action="master_volume" />
<map value="SAMPLER_VOL" action="sampler_volume_master" />
<map value="PADMODE_HOTCUES" action="pad_pages 1" />
<map value="PADMODE_AUTO" action="pad_pages 2" />
<map value="PADMODE_MANUAL" action="pad_pages 3" />
<map value="PADMODE_SLICER" action="pad_pages 4" />
<map value="PADMODE_SAMPLER" action="pad_pages 12" />
<map value="PADMODE_SAMPLER_VEL" action="pad_pages 16" />
<map value="SHIFT_PADMODE_HOTCUES" action="pad_pages 5" />
<map value="PADMODE_HOTCUES2" action="pad_pages 9" />
<map value="SHIFT_PADMODE_AUTO" action="pad_pages 6" />
<map value="SHIFT_PADMODE_MANUAL" action="pad_pages 7" />
<map value="SHIFT_PADMODE_SLICER" action="pad_pages 8" />
<map value="SHIFT_PADMODE_SAMPLER" action="pad_pages 20" />
<map value="PAD_1" action="pad 1" />
<map value="PAD_2" action="pad 2" />
<map value="PAD_3" action="pad 3" />
<map value="PAD_4" action="pad 4" />
<map value="PAD_5" action="pad 5" />
<map value="PAD_6" action="pad 6" />
<map value="PAD_7" action="pad 7" />
<map value="PAD_8" action="pad 8" />
<map value="LED_PAD_1" action="pad_button_color 1" />
<map value="LED_PAD_2" action="pad_button_color 2" />
<map value="LED_PAD_3" action="pad_button_color 3" />
<map value="LED_PAD_4" action="pad_button_color 4" />
<map value="LED_PAD_5" action="pad_button_color 5" />
<map value="LED_PAD_6" action="pad_button_color 6" />
<map value="LED_PAD_7" action="pad_button_color 7" />
<map value="LED_PAD_8" action="pad_button_color 8" />
<map value="PAD_1_VEL" action="pad_pressure 1" />
<map value="PAD_2_VEL" action="pad_pressure 2" />
<map value="PAD_3_VEL" action="pad_pressure 3" />
<map value="PAD_4_VEL" action="pad_pressure 4" />
<map value="PAD_5_VEL" action="pad_pressure 5" />
<map value="PAD_6_VEL" action="pad_pressure 6" />
<map value="PAD_7_VEL" action="pad_pressure 7" />
<map value="PAD_8_VEL" action="pad_pressure 8" />
<map value="PAD_PARAM-" action="pad_param -1" />
<map value="PAD_PARAM+" action="pad_param +1" />
<map value="SHIFT_PAD_PARAM-" action="pad_param2 -1" />
<map value="SHIFT_PAD_PARAM+" action="pad_param2 +1" />
<map value="FX_PARAM_1" action="var 'samplerfx' ? effect_slider 'sampler' 1 : effect_slider 1" />
<map value="FX_PARAM_2" action="var 'samplerfx' ? nothing : effect_slider 2 1" />
<map value="FX_PARAM_3" action="var 'samplerfx' ? nothing : effect_slider 3 1" />
<map value="FX_ON_1" action="var 'samplerfx' ? effect_active 'sampler' : effect_active" />
<map value="FX_ON_2" action="var 'samplerfx' ? down ? set 'fx2down' 1 : set 'fx2down' 0 : effect_3slots_layout ? effect_active 2 : down ? set 'fx2down' 1 : set 'fx2down' 0 " />
<map value="FX_ON_3" action="var 'samplerfx' ? down ? set 'fx3down' 1 : set 'fx3down' 0 : effect_3slots_layout ? effect_active 3 : down ? set 'fx3down' 1 : set 'fx3down' 0 " />
<map value="SHIFT_FX_ON_1" action="var 'samplerfx' ? effect_select 'sampler' +1 : effect_select 1 +1" />
<map value="SHIFT_FX_ON_2" action="effect_select 2 +1" />
<map value="SHIFT_FX_ON_3" action="effect_select 3 +1" />
<map value="SHIFT_FX_PARAM" action="effect_slider 2 & effect_slider 2 2 & effect_slider 3 2 " />
<map value="FX_PARAM_2_SOLO" action="var 'samplerfx' ? effect_slider 'sampler' 2 : effect_3slots_layout ? nothing : effect_slider 2" />
<map value="FX_PARAM_3_SOLO" action="var 'samplerfx' ? effect_slider 'sampler' 3 : effect_3slots_layout ? nothing : effect_slider 3" />
<map value="LED_FX_ON_2" action="var 'samplerfx' ? var 'fx2down' ? blink 400ms : off : effect_3slots_layout ? effect_active 2 : var 'fx2down' ? blink 400ms : off" />
<map value="LED_FX_ON_3" action="var 'samplerfx' ? var 'fx3down' ? blink 400ms : off : effect_3slots_layout ? effect_active 3 : var 'fx3down' ? blink 400ms : off" />
<map value="FX_ASSIGN_AUX" action="toggle 'samplerfx' & setting 'samplerShoweffects' 1" />
<map value="LED_FX_ASSIGN_CH2" action="var 'samplerfx' ? blink : effect_bank_load 2" />
<map value="FX_ASSIGN_CH2" action="var 'samplerfx' ? set 'samplerfx' 0 : effect_bank_load 2" />
<map value="FX_ASSIGN_CH1" action="var 'samplerfx' ? set 'samplerfx' 0 : effect_bank_load 1" />
<map value="SHIFT_FX_ASSIGN_CH1" action="effect_bank_save 1" />
<map value="SHIFT_FX_ASSIGN_CH2" action="effect_bank_save 2" />
</mapper>
I’m wondering what works what doesn’t, is it ipad with djay pro?
@Omar_Becerra are you able to make it work?
I cant wait see if its working on dj707m with ipad, that will be so awesome, maybe you guys make video if possible please
I don’t understand this company ignoring a great controller that people love? We pay money for the software, how hard is it to support it?
Hi @djwolffie, thanks for your interest in adding support for this hardware. The dev team is aware of user interest in this hardware and is investigating it further. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand and prioritize it against other hardware requests. Thanks!
@djwolffie please also refer to this topic regarding Voting and Hardware. Thanks again for pushing the discussion ahead for this hardware!
First thing I did. thanks. Currently working with Apple on a refund as I only signed up for a trial. None of my controllers work with the software! I had cancelled so it should not have charged my account.
Thanks for the additional info @djwolffie. I have also passed these comments onto our dev team. Out of curiosity, what other controllers do you have that are not supported?
Hello everyone,
is there any news about this controller?
For now I’m only using Algoriddim on a late 2023 macbook pro with shortcuts, but I’m looking to buy a controller.
Anyhow I felt in love with the Roland dj707m. So if you see a possibility to use it on a macbook pro let me know it ![]()
Greetings from Germany
Its been more than a year I was hoping this to happen, I hate to be the one tell you this “Not happening”
Roland is not active in Dj segment now, and Algoriddim only interested in hot selling products, regardless a handful of us voting and asking it to happen, I suggest, choose a hardware from their supported hardware list, don’t buy a hardware with hope of software to support in future, its tiring
actually this request, I put in three years ago. I’ve moved on. Agree with your assessment. Never buy with hope of a future enhancement.
+1 vote!. Roland DJ 707M with IPad would the best mobile solution.
I also thought about this controller for a while, but then decided on a setup consisting of a controller and an external mixer. Of course, it’s not quite as compact, but if one component fails, I think it’s easier to find a replacement, especially when things need to be done quickly. I don’t know how likely this is, but I feel more comfortable with it.
+1 for support. This would be an amazing controller with Djay Pro!
Has anyone at all managed to create their own mapping, even a basic one to start off with?
I’ve fully switched over to Djay Pro from Serato and really enjoy using it, but since the Roland DJ-707M isn’t natively supported, it’s just been sitting unused. It’s such a great controller, and I’d love to keep using it with Djay Pro. If there aren’t any plans for support, I may have to consider selling it—which I’d really prefer not to do. Just hoping for any updates
. Thanks!
Just adding my thoughts to the mix to. I’d love the 707 too. The only other option is the Denon MC6000 that does appear to be mapped but those aren’t in production anymore and I do trust buying a 10 year old used product on weddings.
Hi Algoriddim Dev Team, can you give an update on whether or not the Roland DJ 707m will be supported or at least under consideration? Its size and features would be amazing with DJay Pro. Looking forward to your response!
Hi @A_M , welcome to the Community! Yes, this hardware is under consideration by our hardware team, but I cannot say more than that.
