Sync libraries over wifi between devices
Brand new Djay Pro user here, and really excited about this change in my life :smiley:
Been a DJ for 36 years (last 15 only wedding DJ), changed from scratch live to Traktor almost 20 years ago, and have been with Traktor until now.**
One of the most important aspects for me is library management and a fast workflow.
Up to now, IĀ“ve used Lexicon to create a new crate or crates for each of my weddings, as well as fixing tags, writing comments, etc. Then I sync to Traktor on my Mac Studio at home, check beatgrids, create cues, etc. Then I sync the folder I have the ā€œnew songsā€, and the Trakor ā€œcollection fileā€ (that has all the beatgrids, cues, playlists, etc) by wifi using Freefilesync to my other 2 macbooks, this way my libraries got synced.**
Is it possible to do it the same way on Djay Pro? Or is there an easier or better way?
I would also like to sync some of the crates to my ipads, but not all the music, only selected crates. Is this possible?**
I would prefer not to use any cloud based sync apps, as I don“t want to keep them synced all the time, but only when I want (when I get back from a wedding, or once I“ve finished preparing 3 or 4 weddings). I already had an issue when I deleted by mistake part of my music collection and I forgot that my cloud app would delete it from all my computers.**
I“ve seen about One Library, but I would prefer not to use USB sticks to move the files around. Not sure if it can be done over wifi though.
I also just ordered a white FLX10, an Inpulse 500, and found an old Reloop Mixtour that I had never used, so also looking forward to playing with new devices, after so many years only with my S4mk3.
TIA!**
The same process works with djay Pro.
  • sync Lexicon with djay Pro
  • copy the djay Pro folder → /Music/djay or file → djay Media Library to the other device.
Yes. OneLibrary USBs will sync only the crates/playlists you have chosen. Please note: on iOS, USB sync is one-way, but on a Macbook, USB sync works in both directions.
OneLibrary playlists can be transferred over WIFI using virtual USBs (see post below). Please note, the method only works with Macs. You still need a hardware USB stick for your iPad.
Amazing @Michael_Wisniewski, thanks for sharing!
@OAlgo please let me know if this answers your questions.
For more on OneLibrary, please see links below:
Thanks a lot for all your help!
I“m going to try all these over the weekend and will report back
hope you have a great weekend!
Sorry I haven“t got back to you yet, but I haven“t gotten around to trying it yet.
Been working on other things and getting my playlists sorted before I start with this.
I“ll get back as soon as I“m on it
Thanks!!!
No problem. Sounds good @OAlgo
