Sync problems when using two laptops on Reloop 8
We used this set up for the first time the other evening - with both laptops in 4 deck mode, one on 3 and 4 and the other on 1 and 2.
This works fine but I had endless problems with syncing.
Nothing seemed to work properly - when i pressed the sync on a track, the speed would often change to a random figure, the sync light wouldn’t turn on and so on.
I just couldn’t figure out what was going on - could someone explain how this works?
@Tony123 here’s an article explaining how the Sync function works in djay. Please note that this will not Sync across the 2 different laptops. You will only be able to Sync the tracks on each laptop individually.
https://help.algoriddim.com/hc/en-us/articles/360011647580-How-does-the-Sync-function-work-
I explain more how the Master Tempo works in this thread:
If you want to keep the songs across both laptops synced you will need to use the Ableton Link feature in djay on both laptops.
This is so helpful, thank you. I will have a good dig through all this.
Where we were playing had no Wi-Fi but I now can see that we can use Ethernet to get ableton link going.
@Tony123 you’re welcome. Happy to help. If you’re using Macs, I believe you can also create a device to device wireless network connection without wifi.
@Tony123 I also talk more about Ableton link in another thread.
