I’m using a Ddj 1000 srt with m1 MacBook Pro. When using the sync sometimes I’m not able to adjust the tempo of the tracks when sync is on with any of the tempo faders. To fix issue I have to disable sync then keep moving the tempo fader until it starts working again. This only happen when I use sync at the moment.
Hi @DreMisfit,
I believe what you’re experiencing is normal behaviour. This is called soft take-over. Please refer to the topic linked below for more information.
