Lukas almost same thing! In some songs when i use the sync Suddenly turnes of! I sync again but nothing! I use dj2 with wego3. I tried to push the sync right from the ipad but it doesn’t stay stable! Only with some songs! Not always! Maybe a bug?
Lukas i have the latest version. always the promplem was with some songs to sung them. not all. i will try to sent you again from my sets some song i wiil see on reial time oe a video. i have the ipad air 128 and djay 2 2.8.5
Maybe you are right! It might be a good idea what are you proposing at! And of course its a disappointment trying to sync on a gig! It start try syncing and when you are mixing the sync doesn’t hold!!! We’ll see!! Thanks
we are sorry but downgrading is not possible due to the Mac App Store distribution.
Also since the update the beat synchronisation was not changed.
Nevertheless we are doing our best in order to find patterns in the songs which are not getting synced and try to provide workarounds. So you guys are helping us a lot by providing as much not working songs as possible.Thanks for that.
we are very sorry to hear about your issues, after our recent sync update we are very interested in not stable syncing.
Which version of djay are you using?
Why isn’t this fixed yet!? Same exact thing, updated iOS then djay and sync not only turn off but drifts all the time! I have tried both djay2 and djay pro and all has same issue. Very frustrating!
In response to the request below, I have to echo Lukas statement. The issue happens often with many songs(syncing often starts and then un-syncs after 5-6 bars or won’t sync to begin with). I will send track the next time I notice the issue, but I have had multiple occurrences of this issue (ONLY since last update)
Hey Algoriddim- If the issue can not be resolved cant a quantize feature be added to SYNC to keep tracks with drift and the function in working order???
Also- while on the subject of SYNC function… SYNC used to sync to the beat and when pressed again, synced to the offbeat. This function WAS VERY needed because often songs need to be synced with one to the offbeat in order to sound cohesive… sure would be nice for that function to return.
Hi Lukas,
Thank you for your answer. The fact is it happens with all kind of stuff. Since real 70’s disco to house or other edm and no matter if its on spoty source nor dowloaded library…
Anyway, if you feel it’s important for the sake of the issue to have two tracks that had experimented the autosync-off I can send’em to you.
