Hi everyone,
I’m using Djay Pro AI on a MacBook Air M2 (2023) and an iPad 4. generation .
All my music is stored on an external hard drive.
I’d like to know:
How can I keep my playlists synced between my MacBook and iPad (offline solution)?
And how can both devices access the same external drive?
I never use them at the same time — it’s always either the MacBook or the iPad.
I also have no internet connection, and my music is not stored in iTunes or any online platform.
Has anyone found a good offline workflow or a smart solution for this setup?
Thanks a lot for your help and any tips you can share! ![]()
TABAN
