Since June, Tagami has received a whole host of new updates, making it into a comprehensive toolkit for DJ’s. Much more than a tag editor now….
Explore your music with new and improved high quality waveforms and a zoomable second waveform. Navigate with keyboard shortcuts. Customise waveform colours in settings.
Read, write and trigger cues and loops from DJAY (and other app’s) using the toolbar, keyboard shortcuts and the new Cue/Loops panel.
Perform bulk actions on cues and loops (for selected songs) such as
- Set colour
- Set name
- Set cue slot type
- Delete cues
- Sort cue slots
- Move cue slots
- Snap cues to grid
- Transfer cue’s to to other DJ apps
Generate new playlists (or re-organise current playlists) using defined rules with the playlist generator.
Export your entire Tagami collection or individual folders or playlists to Music.app, DJAY Pro, DJAY Pro external apps and other DJ software with the new export options…
Find music you don’t own yet with Tracklistings. Simply paste in a tracklist from anywhere and get links to find the music on your favourite sites.
The new info panel shows entire playlist info when no songs are selected now and contains filters, for comment tags, key, bpm and genre. These can be stacked with Tagami’s smart filters and applied to any playlist, making all playlists smart lists in Tagami.
Other Tagami toolkit actions include:
- Convert selected files to AIFF or MP3.
- Import BPM from DJAY db and write to BPM field
- Import Key from DJAY pro and normalise key for selected songs to different formats
- Rename selected files with rename patterns
- Copy, Move files with 3 levels of destination filing structure
- … & more
For those not familiar with Tagami, it started out as an efficient tagging tool, that offered the ability to add keyword tags to the comments field with keyboard shortcuts, so they could be used in smart playlist and DJAY filters. Just paste in a text list of tags and Tagami auto assigns a keyboard shortcut. Shift+Keyboard shortcut filters by the tag.
The 14-day trial and the save limit are gone. That’s been replaced with a free forever version and pro version with no subscription.
Check it out at: https://tagami.au/
Thanks to all those who have supported and helped with feature suggestions and bug reports.
Tim
