Device model (e.g. 2018 iPad Pro:
Version of operating system (latest iOS):
Version of djay (e.g. 5.2.7):
Hardware/controllers used (e.g. X96, DVS):
Summary of the issue:
randomly tempo jump to something extra different BPM over the original tempo, then you can not reset it!
How to reproduce the issue:
I have realize that, once a song running on deck B, and prepare the next song on deck A, BPM jump to something totally different as I expected!
Hi again @DJ-Z, our team thinks this could be DVS related. Can you please change the songs back to Dynamic BPM and try to capture a short video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
Hi @DJ-Z, yes, our engineering team has several DVS systems for testing. Were you able to capture this issue that I can share with them to aid in troubleshooting this further?
Hi again @DJ-Z, I never received a video as requested above. If you are able to capture something, then I will definitely share this with the engineering team to see if we can get to the bottom of your issue. I have reopened the topic for another week. I hope that helps!
Hi again @DJ-Z, the engineering team is investigating this further. In the meantime, they have suggested as a quick fix it’s probably a good idea to turn off sync when you are playing around with the inactive deck. I hope that helps!
