Track stops playing - only a reload fix’s it
  • Device model: iPad Pro m4
  • Version of operating system: latest IOS
  • Version of djay (e.g. 5.1.2): latest
  • Hardware/controllers used: Reloop Mixon 8 Pro
  • Hardware firmware version (e.g. 1.0.1): latest
  • Some tracks load, the moment there is any interaction, it just stops playing - interactions such as hot cue, start stop, jog wheel
    Sync and key lock is on
  • Problem happens even when sync and key lock is off
  • Sometimes a track will be most of the way through playing and will just stop
  • I have tried restarting iPad, DJAY and re-analysing all songs
  • All songs are saved to iPad hard drive, not streamed
  • Most songs are aiff
  • This has been happening for the past 3-4 months (last 2 DJAY updates) but is getting worse
  • No buttons on the controller have any effect - complete track freeze on that channel - the other channels can still be used and will still play if a song is loaded
  • My DJAY collection library is 2 years old (in that I have more than 150 sessions/previous playlists saved) and roughly 4,000 songs at any given time
19 posts were merged into an existing topic: Missing waveform and no audio M4A local file
Merged with existing topic: Missing waveform and no audio M4A local file
