Thanks for the additional input @IAmTheUngulate
voted
adding modifiers is cruical to build complex mappings
Djay already supports one shift layer, but modifiers enables far more welcome complexity
Thanks for the input and vote @dj_estrela
hey, just keeping this suggestion open and active. Another thought I had was with the Selected Deck option. If I want to set up one side of the controller to be able to switch from deck A to C, and the other side from Deck B to D, I can’t do that if I tell the deck selector to go to C or D, because then all the controls under Selected Deck go to that deck, rather than just the ones I want to switch. This could be fixed by implementing a modified Selected Deck assignment, where you can choose between which decks you want that command to be able to use (ex. this Play button works with either Deck A or C)
