Hi @Temitope_Oyebode, thanks for the feedback. The temporary work around is to disable iCloud Syncing for djay. Please see above. Thanks!
On this issue, I had to uninstall djay and re-download the app it works normally but have not yet played with Djay for a longer period of time so I canât say if the issue will happen in my next gig of a longer period so Iâm still hoping the issue wonât reoccur
I have been experiencing lagging when I am doing more than maybe 3 hours.
Hi @Nubium,
Thanks for sharing this info, and sorry to see youâve been having trouble.
Could you provide any and all additional details regarding this lagginess for our teams to further review?
Is this easily reproducible? Thanks!
Dj for over 4 hours and lag happens,
Do you have iCloud enabled in the DJay App @Nubium?
Hi. No I do not use that
Could you share your dj set up?
Mac, IOS or windows?
Version of Djay pro?
Are you using a controller or DVS?
Yep.
Mixon 8
iPad Pro 11 inch 4th gen , iOS 18.2
djay pro 5.2.7
Ok. You donât use that⌠but it could be default enable.
Did you check it?
Itâs under: Settings > Advanced
Oh. I looked at the iCloud settings on my iPad and it was turned on for djay pro. can this cause an issue?
Unfortunately, Yes.
You can read this in this same topic where you added you problem.
Please turn it off and tell us how that works.
Hi everyone,
Thank you for all the thorough updates youâve provided us with on this topic.
We are still looking into the issue and should have an update soon regarding next steps.
Thank you all for your patience, and please keep an eye on this thread for any updates from our teams.
