A question about using 3rd Party LOOP SAMPLE PACKS inside the LOOPER feature of DJAY PRO AI
Hey dudes,
Is there any way I can add my own Loop Packs or 3rd Party Loops to the Looper in DJAY PRO AI or alternatively use, say, my Launchpad X, to play my own loops (as in 4 bar sample drum loops for example) along side and in time with DJAY PRO AI.
Just to make clear, i mean the LOOPER not the Sampler in DJAY PRO AI. So Instead of loading the Retro 80s Looper Pack into the Looper inside DJAY PRO AI, I’d like to load my own set of Drum, Kicks, Percs, Tops, Bass, Fx, Arp Sequences, Leads and Vocal loops.
Long time player, first time poster… I’ve been searching for a year for this answer and need to know now!
Thank you,
Manek
I use Mac Mini (M1, 2020) Apple M1 Chip. 16GB Memory. macOS Big Sur. Version 11.8.2
DAW: Logic Pro X
