Just logged in to say IT IS WORKING! I’m on Windows 10 latest update, using a Focusrite Scarlett 8i6, I can perfectly hear STEREO sound coming out and have STEREO cues using the setup described here, ASIO BRIDGE and djaypro (bought two days ago)
Now my dream has come true, an excellent software that uses you already filled with mp3s HDs plus Spotify (my main reason to buy it) At first my heart was almost stopped when I’ve discovered you can’t use (like most programs) two soundcards at the same time, one for PA and another for monitoring cues.
It was worst when you realize that the split option offered means MONO output…
(mono in left for PA and mono in right for monitoring) you also need to buy/make a special cable for it.
Anyway now I’m more than happy because I dont have to use that kind of tricks, I can get a loud monitoring coming from the Scarlett and all the dj’ing is made by this unvelievable cheap and incredible Numark DJ2GO (less than $ 100 here and probably less than that elsewhere in the world).
So now I choose songs from Spotify, mix using DJ2GO which already has all the buttons you need for it and keep a clean sound and monitoring out of my Scarlett, this is PERFECT! Thank you guys I was close to put one star just because you dont know already how windows manages soundcards but… this is AWESOME, 5 stars!!!
