I noted a problem today with two USB sound cards, a generic dongle and Fiio E07K, in iOS 8 on an iPad Air. Genuine Apple Lightning to USB adaper used. Worked in iOS7.
Playback works via USB ftom both when they are the only output device.
Plugging headphones in to the headphone port will bring up the usual output / pre-cue menu, at which time playback stops working from USB and starts working from headphone jack.
A reboot had no effect.
This behavior seems to be very similar in Traktor as well.
thats good to hear. I’ve had the pre-cue issue on iOS 9.3.5. BTW, I’m using the new dragonfly black low power DAC which is the only one which works powered via iPad.
I’m nervous upgrading to iOS 10, how’s your experience been? I’ve had a queue crash issue under iOS9, which I’ve posted. It’s difficult to know what are App or OS issues.
Has anyone had any luck with this? I think support acknowledged the issue, but waiting for a fix …
I wonder how compatible the App remains when there are IOS point releases.
Hi Staff,
As we’re now on iOS 11 and soon to be V12, can dJay / iOS support master sound out via lightning / sound card and pre-cueing via the headphone socket?
please advise,
Hi, I’ve got the Zalman RSSC working with the Apple iOS USB 2 cable - works great. Then I bought the Apple iOS USB 3 cable as that would allow to charge at the same time. This however doesn’t work, the Zalman card is not giving any sound. Is this something other persons have as well? Is it something that can be fixed?
We’re already investigating this problem as mentioned above. It has been reported that this issue also occurs with other apps besides djay, so it’s most likely not a direct issue caused by our app. Nevertheless, this doesn’t mean that we’re just about to ignore it. We’ll do our best to find out what’s causing this and fix it (if we can).
