Issue is under related to NeuralMIX in the FX’s Pad section doesn’t work.
For example I have “echo” selected, I click on the echo, then the drop down with different type of FX is in there.
at the bottom, it has “deck” selected by default. When I change it to Drum, Bass, Melodic… . The text is set to whatever I selected.
But when I click out of it to get back to the main screen. It reverted to “deck”.
