Had continued issues of it randomly exiting loops, the loop is still highlighted but it moves past it! I do have a video of this!
My new issues are more worrying! I’ve had the bass completely go on one channel for a song I play every week! Like it’s compressing, I then reloaded the song and it worked fine. The week before on the other channel it went quieter and distorted for like 3 or 4 songs then was fine! Which makes me think it’s not my hardware and it’s the software struggling or something. Any ideas?
I can’t find iCloud syncing in the Djay advanced settings! its not there on mine. Ive gone into my iCloud settings and disabled syncing, what will this help with? I’ll do a firmware update on my Pioneer.
Hi @John_Copley1, iCloud Sync automatically syncs track metadata generated while using djay on your Mac, iPad, or iPhone. This includes cue points and loop regions per song. There was a known issue with CloudKit that affected a small number of macOS djay users. This caused performance issues like what you have described. The process above resets the CloudKit and has cleared up these issue for most users. This is a one-time reset process. I hope that helps answer your question.
For more details on iCloud Sync, please refer to the FAQ below:
Hey, not this hasn’t really helped, haven’t had sound issues again but the loop thing happens all the time and I can see now a lot of people are having the same issues.
Thanks for confirming that the sound issue was resolved. We are already tracking the loop issue in another topic so I’ll consider this one resolved. Thanks again!
