How about a view when you use a controller, especially Reloop Buddy or other supported controllers? What I mean is a big overview so I can see every important parameter happening when I use a controller on a big screen for example iPad Pro. I only want to use the screen when needed for example changing effects or start a drumbeat etc.
Hi! Thanks for replay. This could be a real dealbreaker to use any controller with Djay Pro AI and see any or the most important things on the screen without tapping multiple folders and change views, it’s not so inuiative when you use a controller. I really think this is a gamechanger if you implement this on a iPhone/iPad/iPad Pro when you use a controller. Of course you could change this in the settings if you prefer the old view.
