The .midimapping files for DJay 2/Pro/Etc. are the same on Mac, IOS, and Windows
I hear ya, but the .midimapping file from the zip file for Mac, will give you the exact same result as full support
Download the zip file for the DJay 1.4.5 version (for Mac), then unzip the file to the desktop of your Windows computer
You can download the LE version zip file here
- Look into this to open up the Application folder of Djay Pro
http://www.intowindows.com/how-to-accâŚ
The Djay Pro folder under WindowsApps is named âAlgoriddim.djayPro_1.0.26480.0_x86__ysvet2nbq0e5eâ or something like that
Find the âMidi Mappingsâ folder there, open it, and copy the âPioneer DDJ-RR.DjayMidiMappingâ file into the âMidi Mappingsâ folder
Now try to start Djay Pro with the controller attached
Best regards
Brian
Is it that you donât have permission to write the ddj-rr file in the âMidi Mappingsâ folder? If so, you only need the rights, youâre nearly thereâŚ
Hmm, so close but no cigar
It worked on my PC at work, at least regarding the rights, so I could copy the âPioneer DDJ-RR.DjayMidiMappingâ to the equivalent folder in the Djay Pro Windows App (I donât have a controller at work to test with)
The only thing you need is a bit help with the rights in that particular folder Maybe you can google that a bit more
You are so damn close to success Donât give up WahdeâŚ
Otherwise all my work and yours will be wastedâŚ
Letâs show them Algoriddim dudes whoâs the champs
Look in the text above to obtain the midimapping file You then need the âcamera adapterâ (the one with power input option, so that the iPad donât run out of power)
Then you need to place the midimapping file under Djay Pro documents by syncronizing with Itunes
Then youâll be good to go
Same can be done with controllers that donât have external power also. You just need to connect the iPad and the controller via an USB hub
Best regards
Brian
I have a Solution, more of a recommendation. Isnât the DDJ-RR specifically intended for Rekordbox DJ Software as opposed to the DDJ-SR which Natively supports Setato Plug In Play?
Waiting News!
Please map this Controller! Would love to use it with the RR.
Virtual dj ya lo ha incluido y funciona todo a la perfecciĂłn, ahora es el turno de djay pro, animos! gracias!
Apple just released an upgrade that comes with ddj rr ddj rz ddj rx compatibility
Why Virtual DJ support it and DJay not?
That would be awsome!
any news?
I bought my son DDJ - RR for Confirmation and he has not been able to work it with Spotify.
Please answer this tread and tell us if it planned to support it or not. And when that might happen. My son is very impatientâŚ
