DJM A9
- DDJ SP1
- RANE12 MK2
- EFX500
- NOVATION MINI PADMK3
- IPAD PRO
- Is it possible to get the ipad working with the above setup so that I can use the ipad as a possible pad?
Hi @Fatman, can you please describe in more detail what you’d like to do with the iPad?
- If your mixer has a second USB computer input, you could connect your iPad and run another instance of djay on it. Then potentially route that session of djay to specific mixer channels if your mixer supports that functionality.
- If instead, you want to use the iPad as a MIDI pad controller, you could look at something like the TouchOSC iOS App.
- Myself and another user have used TouchOSC to essentially make a djay remove controller:
A. iPad Remote for djay on Mac - 2026 Update
B. iPad Remote for djay on Mac - #33 by Slak_Jaw
