…sigh…you and me both buddy.
It depends on the AU, but DJAYs implementation is not very sophisticated as most hosts would show (e.g.) a dedicated preset navigator.
Recalling the latest AU & settings on startup would be very nice too as you’d most likely use the same master effect every time.
Digital audio is fun.
Where it gets less fun is when you run into companies who discover they may run into liability issues by giving users a feature that may break some clause in a contract they have with another entity.
As I recall from when I looked into it, InterApp Audio busted something - either rights/royalty tracking or DRM, so it got dropped because somebody didn’t want somebody else’s lawyers knocking on doors with cease and desist orders and a summons to a liability case.
This is why Neural Mix doesn’t work with Tidal streams any more.
Now - that all said, AUM still is a neat option, as is Existential Audio’s BlackHole (for those in the Fruit Company’s orchard), And I’ve seen other options for people whose systems may be connected to soundcards that support Dante (RME has a few options, if you care to dig in), such as the one just announced by this company
See? Digital Audio is fun. Yes yes, you’re just a simple DJ. but you opened pandora’s box so I felt it necessary to oblige your desires with possibilities if you’re prepared to invest and do some extra work to make it work.
If you need help, let me know.
UPDATE: if you’re curious about who that Dante guy I mentioned is, https://youtu.be/LWGVoxiIRIA?si=l7g5MKCWZLLoLonT
Now do you see why I say Digital audio is fun?
Do you have a source?
Edit: recording your set is always possible. Streaming too. There’s more options than mentioned above. Even Apple has free ways to send audio over the network in the box (AUNetSend). Other options to look into are for example NDI related tools (also as VSTs for Win & OBS compatible) but there are plenty.
One virtual cable I wanted to post here for future reference: Blue Cat's Connector - Audio and MIDI Streaming Plug-In (VST, AU, VST3, AAX)
On the hardware side of things I can recommend Audio Interfaces — iConnectivity as they allow you to route multichannel audio between devices with a ton of flexibility.
people have been complaining about it here?
The solutions I offered in that post are only a small glimpse into what’s possible/available based on what I’m aware of, (Dante is local Audio over IP; in-house/venue, intranet, LAN, but there are undoubtedly bridges to internet like OBS) and were to answer OP’s question about using add-ons/plugins for effects. Showing up at a gig with Dante connectivity would be…next level. If you really want, I can go buy my friend who works for the metal beachball-headed rodent DJ a beverage and see what’s happening in that world/level (he’s actually the guy who turned me onto the RME stuff)
The app is FANTASTIC on my ipad pro BUT… What is up with AU connectivity??? Will it ever be a thing? If not I would like to know so I can stop holding out for it and deal with the BS workaround I am currently using.
Cmon guys and gals…
Hi @James_Redou
Could you share some more insights on the setup you are using and the current workaround? What would you like to see in the future?
We’ve been trying for years to get this on the new version unsuccessfully, we get the same reply.
Still works on the old version.
It would be great to know what Audio Unit Effects or general setups you would like to achieve. This is very valuable for the process of supporting. Therefor, please feel free to share your setup requests, audio unit effects etc. in order to help the process.
+1 for this - not being able to route internal audio pretty much means Djay pro needs to be used alone. I can get around it by using an external sound card and having a separate computer, but it would be lovely to have more stuff internally routed on just the ipad for more stripped down gigs
For those that use AUM (or other any iOS daw) it would be so nice to have djay show up as an IAA from inside of AUM. That way you can set it up on a channel and add synths, beats, effects on other channels and route the output however you like.
I mean, AUV3 is great but having djay as IAA would get the job done!
Unfortunately:
deprecated 3 major iOS ago, but maybe iOS17 has a few tricks up its sleeve…
HOWEVER - if you’re a Macbook person: BlackHole: Route Audio Between Apps
follow on their discord - they’ve been working on a replacement/upgrade package called Dipper for those running Ventura. It’s in alpha
Your question:
I don’t see DJAY pro in aum or audiobus3 as an input
Hi @laserr79, please use search before creating new topics. I have merged your new topic with this existing one. This is not currently supported, but you can cast your vote at the top left of the page to show your support for this feature. I hope that helps. Thanks!
If you’re looking to stream from an iPad I’ve found a solution a while back and posted about it.
Basically I connect the Reloop Mixtour/Mixtour Pro to my iPad using a dongle and a [USB Audio Interface](Behringer UCA202 U-Control Ultra… Behringer UCA202 U-Control Ultra low-latency 2 In/2 Out USB/Audio Interface : Amazon.co.uk: Musical Instruments & DJ) to the dongle.
The RCA output from the Mixtour goes into the inputs RCA in the Audio Interface.
Now you have to options, if the app you’re using to stream picks up the USB audio input (eg Mixlr) you’re golden. If not I use Audiobis 3z
Thanks for sharing @RakanIam
Hi! I’m a live musician and lately i’ve been working on building an all ipad setup for live looping and remixing tracks on the go.
So here’s my issue:
I would like to grab sound from djay to route it to my loopy project so i could have a better control over my gain and it would be mind blowing if each deck had options to use different outputs for ex. pre-fader, FX or neural mix with different channels.
My view of potential solutions:
to integrate an AUv3 version of djay so we could route elsewhere
