Hi all.
I’m trying to figure out how to do this transition with djay. Any ideas?
For those wondering what “new transition”, “this transition” and “INSANE DJ Trick” actually refers to, it’s a 3/4 FX setting, as a way of jumping between drastically different tempos.
This can be done by (not surprisingly) choosing a 3/4 setting from one of the suitable FX in DJay.
Thanks for your input. The reason that I’m asking is because I have looked at the 3/4 Effects in the app and none of them seem to do what is needed. But I could be wrong. So I’m opening up a discussion if anybody is interested in helping.
Before I posted, I did the same thing - and I found one. The solution is there if you look for it.
Soooo. You’re gonna make me work for it ? lol.
Think back to your days at school. Would the teachers just tell you the answer, or would they help you to find it yourself? ![]()
Yeah, OK fair enough.
The closest thing I can find is echo out + . But it doesn’t repeat indefinitely. Did you find one better?
Well no, but it’s a transition. It doesn’t need to last forever.
Vote here: 3/4 loop like on cdjs
ok cool. so there is a 3/4 loop hidden that can be midi mapped.
You could also try using the onscreen Pad Loops with built-in HP/LP filter. It will probably take some practice to hit the 3/4 perfectly, but might be worth experimenting with.
Same goes for the Echo Pad FX. This doesn’t show the the 1, 1/2, 1/4 Echo locations so it might be harder to figure out the right spot for the 3/4 Echo.
Thanks for all the info that last one is a bit short but the echo plus is better and it would be even better to have the effect just as long as I wanted.
Is there a way in DJ Pro to recreate this trick here where the DJ mixes from House to DnB by using 3/4 timing maths. https://www.youtube.com/watch?v=ryaBfsh2dpU.
What is the effect called that is the same as 3/4 roll effect? Thanks, J
Hi @Sparkomatic, I’ve merged your new topic with this existing one. Please refer to the discussion above.
