"Your Crates Library contains items that are located in folders that djay does not have access to" error?
  • Device model : MacBook Pro 16 inch 2023, M2 chip, 16 GB Memory
  • Version of operating system (e.g. macOS 14.4.1): macOS 13.3.7
  • Version of djay (e.g. 5.1.2): 5.2.5
  • Hardware/controllers used (e.g. Reloop Mixon 8 Pro): Pioneer DDJ 400
Summary of the issue:
I use Serato with my Pioneer DDJ-Rev 7, and Djay Pro with my Pioneer DDJ-400.
The reason is because Djay doesn’t support jog wheel wave forms on the Rev-7. So I set/prepare my crates in Serato, and the exact crates appear in Djay Pro in ‘my crates’. This suits me perfectly.
Every time I go to ‘My Crates’ in Djay Pro, an error arrises ‘Your Crates Library contains items that are located in folders that djay does not have access to.’. And a blue Botton ‘Allow Access’ appears. Note that this doesn’t affect my crates, I still have access to all my crates and songs and can play them no problem, even without allowing access. It’s just an annoying warning, that’s all.
After allowing access to the required “Users’ folder anyway, and then removing the warning sign, if I ever go out of ‘my crates’ (for instance into Apple Music) and back into 'My crates”, the warning sign appears again. Every time, no matter how many times I 'Allow Access to the ‘Users’ folder.
My question is: How do I prevent the warning sign for appearing every time I go out and back into ‘My Crates’ folder?
How to reproduce the issue:
Hi @DJRedwood, can you please share a screenshot for which path(s) djay is trying to get permission for when you click the “Allow Access” button? There is probably an unusual path being generated. Thanks!
Hi Slack_Jaw, here are the screen shots of the process. Pic 3 shows the file that requires access.
Thanks for the screenshots. I’ve passed them onto engineering for review.
Hi @DJRedwood, it’s possible you have tracks in your Serato library that are under multiple user names on your Mac. That’s probably why the /Users path is shown. You could try and find these greyed out tracks in djay and then figure out where those files are and move them under your main Mac user or remove them from your Serato library. I hope that helps!
Hi The issue resolved it self somehow. Thanks.
Excellent! Thanks for the follow up @DJRedwood
I am having the same issue but the folder /missing it’s asking me is nowhere to be found is there a way to fix this? Please see screenshot of the folder the app is unable to access. I cannot import any crates because of this issue as the message keeps showing up. Please help! I’ve searched everywhere online but still unable to find a solution. At this time I am unable to use this feature!
Hi @Apa, welcome to the community! Can you please provide more details about your setup?
Have you tried searching for this folder on your device outside of djay?
Thank you for responding! I found the culprit! It was on Serato on another device. There was a track missing but the /missing folder can’t be found. At first I couldn’t delete the missing file but found a way to delete it from the crate collection by unchecking iTunes from Serato settings. Now I can import without issues!
You’re welcome @Apa. Thanks for the follow up and sharing your solution. Glad you got it sorted out!
How is this done? It looks like there may be a solution?
Having same issue. Was on the phone with apple support. They said it’s a problem with the software but this doesn’t happen on my other computer so I disagree. Any fixes?
Hi @jmoak311, it’s possible you have tracks in your Serato library that are under multiple user names on your Mac. That’s probably why the /Users path is shown. You could try and find these greyed out tracks in djay and then figure out where those files are and move them under your main Mac user or remove them from your Serato library.
Perhaps this comment from above is helpful as well?
I gained access. Couldn’t tell you how I did but it involved chat gpt lol.
Most of my crates populated in djay pro so I’m just going to continue using those especially since I use beatsource mostly.
Perfect. Thanks for the follow up @jmoak311. Glad to hear you sorted it out.
Getting same error!
Macbook Pro 2019, i7 macOS 15.7.1
External samsung SSD drive, eXFAT - containing serato crates
djay 5.6.1, full disk access granted.
Problem:
Every time I launch djay and try to access SR crates, I keep getting same access error, and I have to allow access again. Is this the norm?
Hi @Armigo, in your macOS Privacy & Security settings, have you given djay Full Disk Access as well as access in Files & Folders?
Yes I have!
Djay appears in both settings
I just double-checked now by deleting djay away from those settings and re-adding back As soon as i quit djay, SR crates still demand access to be allowed. RB Collection does not ask. The issue only happens with SR Crates
