I think the brand âpitch n timeâ is actually owned by Serato so if its that specific form of pitch lock youâre looking for, i dont see it being likely to be added to any other brands products. Its an exclusive for their own software.
first of all thank you very much for your time, the first problem you solved
1 problem still exists
yes i mean phase
There is a video with user who have uploaded videos here where the pitch doesnât match exactly (that i mean pitch in time,sorry for my english
i found another problem with samples,like i sayd i used traktor for samples here in dj pro the samples work differently.I would like a button where the sample plays as long as I hold it down, and not if I press it once and it plays all the way to the master (i hope you understand all my problems) again sorry for my english
Regarding your video, this is how the Cue Button and Temporary Cue works in djay. If you want to change the location of the temporary cue, you can press the Cue Button while the track is paused. However, in the djay Settings>Appearance you can switch to Cue/Jump which might work better for you.
as example for cue what i mean and i believe in djpro is a problem because i play very fast,i will post and another video about the pitch,so about the set/jump i dont understand how it worksâŚ
i dont use ipad but macbook its different layout there from this pictures,i dont use key sync or keylock or crossfeder,macbook pro + flx10
I think youâre talking about Alphatheta and their âsmart cueâ feature whereby the main cue button becomes whatever your last hot cue is. Iâm not sure âplease fix thatâ is the right phrasing as itâs not really broken per se. That feature is exclusive to a couple of Alpha products and the behaviour in Djay where the cue button always returns to the place you set the temp cue is an industry standard by and large.
my friend,i dont play with alphatheta product (only hardware with djpro),as you can see i play with traktor,always when set up loop or hot cue and i pressing CUE as you can see always goes when i used last hot cue point,i think the way djpro works doesnt working well,one friend tells me this before before I make the transition to dj pro from traktor
As i said though, how Djay works is pretty standard behaviour for the âtemporary cueâ across the industry. The cue button is assigned to wherever you set the temporary cue, not linked to a hot cue.
Hi again @Nikos_Filopoulos, as mentioned above, this is how the Cue button working in djay. It is different from Traktor and is not adjustable to match how it is done in Traktor.
Why is a phase meter needed? In Traktor itâs useful when the waveforms arenât stacked, but here they are so you can clearly see if youâre out of sync anyway.
Or do you mean a phrase meter like showing 4.2.1 for the first beat in the second bar of the fourth 16 bar phrase? Every bar is numbered anyway which I have found useful.
