AlphaTheta DDJ-GRV6 Official Support
Thank you very much. I’ll review your comments after dinner. I’m doing this on Windows; I hope that’s not an issue.
I’m also having problems with the jog wheel. I don’t know how to calibrate it… It doesn’t behave like a normal jog wheel.
Don’t reply to me, or I’ll drive you crazy. :joy:
@Santi_Gil for the Drum Roll buttons, you could map these to Bounce Loop Drums:
You’re welcome @Santi_Gil. I hope that helps! Mapping on Windows should be pretty similar by the way.
As for the jogwheel mapping, you may find this post from another topic helpful. It’s a different controller, but these settings might point you in the right direction.
I need support for this on the meta quest🙏
Would you mind sharing what you have so far?
I’m away for Christmas. I’ll be back this weekend and will share it then.
I cannot upload files, so I have to share it through a link:
https://file.io/ZoxSgzbMp9Gd
It’s just the basics, and I haven’t found a good way to map the jog wheels yet. You can use basic functions, stems, and the loop buttons (but not the loop cues yet—I’ll map them tomorrow).
The next steps will be the beat FX and the groove circuit. However, I believe there should be official support for this controller. This is just a temporary workaround to play for a while, not a proper solution.
Thank you :pray:t3:
@Slak_Jaw Whats a good way to import this midi mapping?
Just put the MIDI file in the djay folder on your device. Then load it in the djay Settings>MIDI Devices>MIDI DEVICES.
Hola Santi, el archivo ya no está:
The transfer you requested has been deleted.
Saludos,
Julio
Al llegar a casa lo vuelvo a subir.
When I get home, I’ll upload it again.
Here is the link:
If anyone improves the mapping, please share it!
Hi everybody,I’m new here and been using Djay pro for a while now and loving it! I want to upgrade from flx4 to grv6 but I’m holding out for it to be supported officially! I hope they can fix this soon! Tnx!
We are all waiting for the official mapping. It’s a shame because the controller is really nice. I hate using Serato or Rekordbox, but I can’t wait much longer. I need stable software. I’m not sure if I’ll end up leaving Djay Pro for good.
Yes me 2 i’ve allready installed Serato and Rekordbox to test them out but still think Djay pro is the best… but can’t wait much longer!
Hi, I bought a pioneer GRV6 controller.
When I connect it to my phone, the controllet features do not seem to be configured. Do I have to configure all the buttons one by one?
Thank you for your help
Hi @pardi, this hardware is not yet supported by djay. However, I’ve merged your new topic with this existing suggestion to add support for it. Please use the blue Vote button at the top left of this page to show your interest in addicting support for this hardware. Thanks!
I have bought the grv6 and tried Serato and Recordbox… I do not like them! Just not on par with Djay pro and allready miss using it! Its just the best! So hope it will soon be available!
You should try VirtualDJ
