You’re welcome @Reji. Welcome to the Community!
iPad users could be the biggest beneficiaries of this update. As far as I know, Rekordbox does not allow the use of channels 3 and 4 when used with an iPad, and Serato DJ does not have an official version for iPadOS.
This means that djay Pro could be the only software to support the GRV6 with 4 channels on iPad (assuming it eventually does).
Thanks for the additional feedback @Santi_Gil
Here is the link for My MIDI-Mapping of the GRV6.
Not everything is mapped and some things are mapped differently than what is labeled.
Please follow my TikTok- “matt.the.dj” if this helps you out in anyway.
I’ll post a breakdown of the mapping there if needed.
Thanks for sharing @DJ_NARKOTX
Hi . Thanks. I’ll be interested to know if it “works” well, jogwhells in particular. i dont have the GRV6. but thinking of buyin one.
Hello guys, I create this mapping on “ALGORITHM DJAY PRO” and it works for me, I hope this works for you also.
Thank you so much, this was very helpful to mapped my GRV6 on my iPad
Hi @DAVID_STEPHENSON, welcome to the Community! Thanks for sharing.
Hello everyone! I’m happy to report that the AlphaTheta DDJ-GRV6 is now officially supported.
Here’s a quick breakdown of the unique features:
WE DID IT!!!
Thank you @Slak_Jaw for your continuous support in pushing this to happen!
You’re welcome @DJ_NARKOTX
Hi, what do think about new update and integration for GRV-6 is it covered some like your mapping?
DDJ-GRV6 & djay
Djay GRV-6 Support >>> First Impression - WOW!!!
I started playing with it with my iPad Mini and it’s amazing.
playing 4 tracks with no sweat, stems works perfectly, latency is no issue.
The way I see this is that now I have a DJ workstation that doesn’t fall from the $3200 XDJ-AZ
Thanks guys!
The crossfade stems feature is insanely good! I’m probably going to remap Deck 4 so I can use the knobs to blend each stem separately.
Can you further explain?
Watch this video at 7:50:
I don’t actually use Deck 4, so I’m planning to remap its EQ knobs for stem crossfading. It’s a great fit (one knob per stem), and I still have extra controls left over on Deck 4 for other custom stuff.
i am super curious on how this works, i was planning to get the grv6 to practice and get more familiar with rekordobkx and cdjs, would that be the case? like all buttons and functions match 1:1 or is a totally different thing when used with djay pro ? thanks
There are some differences, I use IPAD and I’ve noticed that the mapping for loops is a little bit different. Didn’t play enough to find some more. the STEM buttons are a little bit different as well. I must say that the crossfade stuff is super cool!
