📣 ANNOUNCEMENT: djay 5.6.4 for macOS/iOS/Windows/Android
Hello everyone! We’re excited to share our latest djay update. It should be rolling out to the various apps stores in the next 24-48 hours.
NEW:
  • Added the ability to add Spotify tracks to your own playlists in My Collection
FIXED:
  • Improved VoiceOver support for Neural Mix routing, crossfader assignment, and title bar buttons (macOS)
  • Fixed cases where audio configuration was not restored correctly when connecting multiple audio devices
  • Fixed missing delete option in the context menu in My Collection (macOS, Windows)
  • Fixed Automix not using the Queue when selected (macOS)
  • Fixed MIDI mapping file compatibility issues between platforms (Windows)
  • Fixed connection off-screen when using Pro DJ Link (Windows)
  • Fixed an error when loading Scratch Tools (Android)
  • XDJ-AZ: Fixed FX BPM not being updated
  • DJM-S11: Fixed library scrolling issue with certain display settings
  • DDJ-REV1: Fixed unmapped buttons for 8 beats in Beat Jump pad mode
  • CDJ, DJM: Fixed issue where last used MIDI mapping was not restored
NOTICE / REMINDER:
Thank you for the constant updates!
Seems the wave integration into the Rane System one is taking a little longer to be full baked.
You’re welcome @eyeseeyou01
Amazing! Thanks @Slak_Jaw !
You’re welcome @James_Gillies
This is a really nice update. I can now build a set list from mixed sources, which is really, really useful. Is this possible with the offline locker in BeatSource? Can I use offline locker tracks in My Collection?
Yes you can.
You boys and girls at Djay are definitely ticking off things from my wish list this year. I am really glad I subscribed to this dj platform.:grinning_face:
You’re welcome @BillPayer. Thanks for the positive feedback!
You guys should definitely add the four dock feature to android (please I want it so bad please)
Hi @starxia, welcome to the Community! There’s an existing Suggestion topic for this if you’d like to upvote it:
4 posts were split to a new topic: Song playback stops
