I have no issues.
Greetz Chris
I have no issues.
Greetz Chris
Thanks Chris for the info
Hi @eecy_cee, please use search before creating new topics. I have merged your new topic with this existing one. Please see above for more details. Thanks!
Thank you Slak_Jaw much appreciated:)
My apologies Slak Jaw, I searched for “Siquoia” I shouldve searched for “Mac OS 15”
I notice with Siquoia it makes DJay run smoother, less laggy, less pauses, this is with home test, this is with all “library backup” file deleted and reloaded my crates from scratch, and without controller,
I find searching songs on “My Files” is better with less lag.
But I will test it out in full on my Sat Gig will report back.
A post was merged into an existing topic: Soundcloud tracks and playlists not loading
Any official support noted for MacOS 15 yet? The official Serato email arrived today confirming their software works, and they are usually the slowest. Are we sticking with the “at your own risk” for now?
Hi @djgdiddy, yes, macOS 15 is officially supported. Thanks!
Is that still the case ?
Nothing has changed in the last 3 hours since I posted that.
Hi @Slak_Jaw i mean this.
Yes, macOS 15 is now officially supported
Sorry for this misunderstanding @Slak_Jaw I asking for IOS 18 stability and performance?
@Digital_Jedi yes, iOS 18 is also officially supported. I’ve personally been running iOS with djay for about 2 months now.
Thank you @Slak_Jaw ![]()
You’re welcome @Digital_Jedi
Even “Siquoia” was wrong, becaus the name of the (meanwhile old) macOS was “Sequoia”.
Greetz Chris
they use the words “Mac Os 15” but I think they are adding “Siquoia”
thats why I also could’nt find the thread.
Hey hey, I am wondering if there’s any known issue with the mixtour pro 2? Djing a gig on Thanksgiving and wanna make sure it’s all good.
So far working great for me on Sequoia as well. This may be a dumb question but once an OS gets the thumbs up, should one be safe to continue upgrading within the same OS e.g the newest 15.2 update. Used to staying a full OS behind on my last software.
Hi @jmoak311, in general yes. However, if you have important gigs on the horizon, in my personal opinion, it’s good to exercise caution and to always have a backup plan. Linked below are my personal recommendations that I shared a long time ago before joining the Algoriddim team. I believe these are still relevant no matter what DJ software and hardware you use. I hope that helps!
