Automix: Sync + Tempo Blend still looses sync
Hello Team,
Thanks for the update..keep pushing.
“Improved tempo change during sync behavior: if sync is active, tempo changes on any deck will now synchronize with other decks, regardless of whether the deck itself is currently audible.”
Please explain, I tested on Automix, still looses sync..
1st video- Automix, Tempo Adjust set to Sync+Tempo Blend.
2nd video set to Sync only.
This is only .01% BMP
Thanks @LaidbackFred, this means that the non-audible deck can now be used to control the tempo as well as the audible deck. For example, Deck 1 is playing and audible through the Master Output (Deck 1 Channel Fader Up) while Deck 2 has the Channel Fader Down (not audible). In the old sync method, if you moved the Tempo Fader on Deck 2 it would not control the tempo of Deck 1. Instead, it would disable sync and move independently of the Deck 1 tempo. In the new method, either the audible or non-audible track can control the tempo when sync is enabled.
Thank you @Slak_Jaw
It’s makes total sense now.
Thanks again for your time.
Can we keep this post or move to Tempo blend as an issue?
It’s been years even beyond when it was called Morph.
You’re welcome @LaidbackFred. Can you share a link to the other topic here please?
What are the settings on the crossfader? Is the Tempo Bland option enabled?
You’re talking about the Mix Now option, as I understand it. I tested it on my iPhone 12 Pro and found no problems. In the left deck I have a 120 bpm track playing, in the right deck I have a 130 bpm track playing. I press Mix Now and gradually the tracks are mixed and at the same time the tempo speeds up from 120 to 130 bpm.
Am I missing something here? With Sync + Tempo Blend the automix drifts. With Sync only (i.e. blend off) the transition syncs perfectly.
Used to work fine with both on before the update.
As it stands now I have to keep the Automix setting to Sync Only. Sync + Tempo Blend transitions with a drift even though the deck Sync lights are on.
Is this a bug or am I missing something?
It’s always been that way.
This issue was never resolved.
I can be sure of this.
This will happen with
Automix and Mix now.
Tempo Blend is the Problem.
Hello @Slak_Jaw
Not sure where the original post is. But here is a conversation mentioning this issue.
I hope this issue is addressed.
Having to reset the Tempo after every transition is a pain.
No problem @Slak_Jaw
I’m here to help.
In this next video, notice the subtle static when resetting the Tempo on incoming song after the mix. Happens all the time.
When I record my mixes. The songs sound their best when the Tempo slider is set to “0”.
Since Sync/Tempo has never worked, this has been my work around to a good mix.
Its a terrible noise, and more noticeable on certain songs.
This is similar to another problem we are discussing in this section, which has not been solved yet.
If Tempo Bland is enabled, there is 0.1%… 0.2% sound distortion when you start mixing… I wrote about it. Same thing when you go from 99.8% to 100%.
Can’t anyone repeat what was described in the other thread? I’m not the only one who has this problem.
Is someone solving these issues?
Hi again @LaidbackFred, can you please double confirm that with Tempo Blend Off the issue does not occur? Thanks!
Hey there @Slak_Jaw
Yes Tempo off problem goes away.
My suggestion in the past was to have Djay reset the tempo on incoming track right after the mix finishes. Easy for me to suggest though.
Thanks for confirming @LaidbackFred
Yes sir. No problem glad to help
Hello @Slak_Jaw
I found this video I made for your team 4yrs ago..
When Tempo Blend was Morph.
I created another video to compare Tempo Blend with Morph.
Sorry to say it’s the same.
P.S. Notice the Beatgrid was RESET?
That has been an issue for years.
Djay reset the Right Track.
Usually when the Track hasn’t been played in long time.
Thanks for the additional info and videos @LaidbackFred. I’ve passed this onto the team.
Hello @Slak_Jaw
We appreciate your hard work.
Unfortunately still the same on my end.
Using the same 2 songs in the video above.
