Hey Team,
Djay resets the Beat Grid when the user opens the BPM Pop up Window when mixing is triggered.
I can send you the songs via email, please let me know.
This has been a pain for me for quite sometime, Finally found the Glitch!
Djay Ai V. 3.8.1
iPhone 12
iPad Pro 3rd Gen
iOS 15.0.2
1, Manual adjust: If you know the correct BPM, type it in after tapping the EDIT pencil
icon and hitting ENTER.
2. Half/Double BPM: Use these buttons if you find the BPM is half or double the correct
tempo.
3. Tap: You can approximate the correct BPM by using the Tap button. While the track is
playing, tap the Tap button in time with the beat until a BPM reading displays.
Once youâve adjusted the BPM, you can tap Apply to save, or Restore to go back to
previous settings.
What it doesnât say is that âHalf/Doubleâ is kind of temporary, even if you Apply to save, it really doesnât save it into the database.
Only way to permanently edit the value is to do Use the EDIT pencil icon and hitting ENTER.
and then APPLY once or twiceâŚ
In the video, you didnât use the pen tool?
Try it with that, ie. you need to put cursor to the BPM field and then press ENTER & APPLY, that should work.
Hey Romy,
Thanks for the advice.
This video is to show how Djay resets the BPMs.
The issue is that Djay will not leave My edit, and go back to itâs original analyst.
Thanks for reporting this issue and for sharing the video to make it clear what youâre experiencing.
So we can get a full picture of why this might be happening, could you also share a screenshot of your Automix settings when this occurs? The reason for this is that when you trigger an automatic transition, djay uses the Automix Mix settings. Iâd like to see if I can reproduce the issue based on your current app settings.
Thanks in advance for your help troubleshooting this!
Thanks for sharing your exact Automix settings. I was able to reproduce the behavior now and Iâve sent all of this information to our Development Team for further investigation. Iâll keep you updated here when I have news about this.
Thanks in advance for your patience while we look into this.
Hi @LaidbackFred, Thanks for the update. Could you please tell me more about this occurrence when Automix wasnât active? Do you mean that you didnât use the Automatic transition option (i.e., tap the right or left facing arrows on the sides of the crossfader), and this still occurred? If youâre able to reproduce it again, please share a video of the steps leading up to the reset without using that Automix transition.
Thanks again for your help in troubleshooting this!
Hello Emily,
The exact same as the video, when opening the BPM pop up window.
Wether or not Automix is active.
Pop up box is used due to the fact that double tapping the BPM reset (blueđľ) doesnât always work. So the habit of opening the BPM pop up window is always used after the transition to reset to 0%.
I donât Double tap because of issue number 2 on the reply below.
I canât use the Morph setting due to its Mixing ability sent to your team via email ticket # 144351. Titled Morph vs. Sync.
Thanks for your patience while our team is looking into these issues. If itâs okay with you, Iâd like to lay out the issues youâve brought up so far individually here, and gather additional information about each one, so that our team can better tackle these and get to the bottom of whatâs going on.
The BPM reset in the pop-up window:
For this issue, I was able to reproduce it one time as I told you, but I havenât been able to reproduce it again since and no one in our team has been able to do so either. For this reason, could you please tell me the following:
Are you able to consistently reproduce this issue?
If yes, does this only happen with specific tracks, or does it seem to happen randomly with all tracks? If only certain tracks, then Iâd ask you to please send over the tracks themselves here.
Could you please tell me exactly step-by-step how youâre reliably reproducing the issue?
Double-tapping the BPM reset (blue musical note) doesnât always work.
For this issue, Iâd like to first make sure that youâre double-tapping the tempo slider to reset it rather than the blue musical note (key lock icon). If this is what youâre doing, and itâs not working as expected, it would be really helpful to either get a step-by-step description of when this doesnât work, or if you could send a video showing this issue and also drop it here, that would allow us to reproduce the issue in order to find a solution.
The Morph Automix setting not mixing as expected from ticket #144351.
Thanks for bringing up this issue as well. Iâve reviewed the messages you had with our Support Team there, and unfortunately I wasnât able to locate the video you sent in at the time showing the problem you identified with the Morph transition. If possible, could you also share a video with some examples where this transition doesnât fit what youâre looking for so our team can get a better understanding of your experience with this?
Thanks again for your help troubleshooting these issues! We really appreciate it so that we can continue improving djay.
Hi Emily,
Thank you for researching these issues.
1.This issue is mostly consistent with songs that Djay wrongly analyzes.
Usually when analyzed at double the speed as the video shows.
Sorry, I did mean double tap the Tempo slider, not the Key Lock.
When I set up Djay, I Sort by BPMs. So if songs are very close to the same but not exact BPM.
i.e. 120.1 to 120.5 BPM double tapping the Tempo slider does nothing. So the habit of using the Pop up window is always used. Thus creating the Reset issue.
On the Morph verses the Sync feature.
Iâve been asking for the reset of the Tempo after each transition for years.
Your team have since gave us Morph.
In my opinion the Morph should reset tempo After, but during the transition.
I will send over all tracks and video. Thank you for your time.
Thanks for sharing the additional information about each of these issues, and for sharing the song and video files. Our team is further investigating these items and Iâll update you here with any news as soon as I can. Thanks again for helping to troubleshoot and for continuing to share your valuable feedback!
I just wanted to follow up here on the issues you shared with us.
Neither myself nor our team is able to reliably reproduce this issue following the steps you showed in your video and using the tracks you sent over. If you are reliably able to reproduce it, could you please provide us with a step-by-step recount of exactly what actions you take in djay that leads to that BPM resetting? It will be difficult for our team to fix this unless we understand exactly how to reproduce it.
Double-tapping the BPM reset doesnât always work
We also havenât been able to reproduce this issue on our devices here. Could you please send a video showing step-by-step exactly what leads up to the issue?
Regarding the Sync vs. Morph Automix setting for transitions, our team has noted this feedback and will take this into consideration for future developments. Thanks again for all of your feedback and for taking the time to share your insights! We truly appreciate you helping us to keep improving djay.
I was able to capture the evidence on video.
I was able to get Djay to consistently reset the Beat Grid after the rebooting Djay.
I was also able to capture in slow motion when Djay loads the track, it will initially load the track to the original analysis but then actually loads my edit of the Beat Grid.
I will send these exact tracks and new videos on your dropbox link.
The actual problem for double tapping to reset the BPM. Is that if two tracks are extremely close but not the exact BPM, Double tapping the slider will not do anything. For me as the user it is extremely important to me that the tempo is at 0%. With great speakers or headphones l can clearly tell the difference if the tempo is not set at 0%.
I will send the video and the tracks so that you can duplicate what it is that Iâm trying to explain. Notice in the video that the BPM is that .02%. This is what I mean when the BPMâs are extremely close. Sync vs. Morph Automix setting for transitions
The obvious is that while Djay is using the Morph feature the two tracks do lose sync during a transition. Most likely tracks that are farther apart on the BMPâs.
But in the Sync mode, Djay keeps both tracks in sync when tempo is left alone during the transition.
Morph desperately is in need of a âReset Tempo after Transition option.
Issues 1. And 2. Were only discovered due to this Morph issue.
As a longtime Djay user, I understand the future in Automix Mode. Therefore no baby sitting should be required in order for Automix to head into the road to perfection.
Thank you and your team LaidbackFred
