Beat Jump - Auto Loop Length
Hi everyone,
Recently I switched over to djay Pro from Traktor after the v5.0 update. The beat grids are just magical.
However, I was mapping my MIDI controller and miss one feature from Traktor: Beat Jump with the Auto Loop length.
In Traktor, alongside with beat jump values …16, 32, 64… they have a “LOOP” option. This takes the auto loop length and makes that the beat jump length.
Like the Traktor X1, I like assigning the Auto Loop length to an encoder, and having two beat jump buttons for back and forth.
The current workaround I have now is assigning the same encoder to change the loop and beat jump length. However, auto loops go from 1/32-32, but beat jump lengths go from 1/32-64. Due to the beat jump having an extra length value, if I turn my encoder too far, I can easily get them out of sync without knowing (and also having it like this anyway is a bad as they can be de-synced for other reasons).
The implementation can look like this below. In the “Manual / Skip” section, along with the “16 Beats”, “32 Beats”… there could be a “LOOP” option in the “carousel selector”… most likely the last option at the end.
For example, if I have my auto loop set at 8 beats, and the “LOOP” option selected like the screenshot above, pressing the beat jump forward or backward button will jump 8 beats. Also, since the beat jump length is coupled to the auto loop length, I can easily check the set length by looking at the auto loop length (the number inside the loop icon, next to the BPM).
I plan to use my iPad and Xone:K2 as my primary DJ setup. It would be awesome to implement this function.
Thank you!
That would work for me too. Simple and elegant!
Thanks for the suggestion @kyleawayan. As a previous Traktor user, I agree. I have forwarded this to the dev team for consideration. If other users could please use the Vote button at the top so we can gauge user demand that would be great. Thanks!
Yes, good idea! Voted this up.
Also regarding backloop function, please take a look at my earlier post:
Pressing the loop OUT button would activate a backloop autoloop with set number of bars:
https://community.algoriddim.com/t/loop-backward-on-out-button-quick-looping/21381/9?u=joris
This is exactly what I’m looking for as well
As a long term Traktor veteran I can only agree! This is one of the most annoying missing features for me currently, without beat-jump I’m simply defeated, I use it every set!
Thanks 4 your suggestion, voted!
Planning on giving a full review myself for DJay Pro, since I might want to switch permanently <3
Yep me too. Devs please make this happen
Often enough, I wish that the Beat Jump & Loop Size values are the same. I do have them mapped with “Duplicate” on the same rotaries/buttons, but I don’t really need them independent. A master setting in General to link the values would be very welcome in my opinion.
Hi @Kaloyan please use search before creating new topics. I have merged your new topic with this existing one. You can use the blue Vote button at the top left of this page to show your support for this feature. Thanks!
Thanks @Slak_Jaw, I’ve seen the thread and voted already. The description was very extensive and some of items discussed are a bit different. The request I wrote is short and simple - just have a global setting.
Thanks for looking at it, the requests are very similar indeed.
You’re welcome @Kaloyan. Thanks for the additional info and ideas. Always appreciated.
It would be so useful to get this feature implemented.
Now the new 4deck HW mode on iPad has an issue with the loop size display. The Skip size can always be seen, but the loop size disappears when showing the tools panels. If they were the same, we won’t even need two values displayed, but only one. So much cleaner and less cluttered.
Thanks for the additional feedback @Kaloyan
Loop duration is on the UI by default, but skip duration is buried. Also there aren’t enough buttons on the Mixtour Pro to control loop duration and skip duration. Please add an option (after 64 beats) to make skip duration the same as loop duration, it’s available in Traktor.
Hi @David_Lane, I’ve moved your suggestion to this existing topic. Please cast your vote for this feature at the top left of this page. There is also an existing topic for 64 Beat Loops: Add 64 Count Loops
Been a year since this was suggested :pray:t2:
I just voted on this. Still very very relevant!!!
As a previous Traktor user that switched to Djay, this would be perfect!!!
UP UP
Don’t forget about the mobile djs
Thanks for the additional feedback @Alon_Sharir1
It’s nice to have skip now available in the crossfader bar in 5.3, but the Mixtour Pro doesn’t have enough buttons to control loop and skip duration seperately. I have duplicated the controls in my mapping but found that if you change the loop duration whilst looping, when you exit it goes back to what it was and skip duration doesn’t.
