I’m an all-round dj and I have tracks which have BPM > 200, mainly rock/metal
Currently it’s pretty hard to adjust the BPM’s for songs which BPM is over 200.
The only way to do it is to “tap” and my tapping with finger isn’t accurate enough with BPM’s are over 200.
When playing rock, I don’t care if I can’t beat mix them. I just want to maintain my library correctly and not having those fast tracks showing for example when filtering based on bpm’s (or on bpm based smart lists).
So could we have an option to
- adjust BPM’s with the metronome
- adjust BPM’s editing with the text field ie. range like 0-1000, currently (50-200?)
This could have an option in preferences like in “Advanced Section”:
BPM range : (Overriding the BPM edit field and metronome)
- min BPM : 0
- max BPM : 1000
Then you just need to figure out how to draw the beatgrid.
With current beatgrid “nudge” tools we can then place the beatgrid nicely.
Please trust as, as we are Dj’s and we know our tracks
We just need tools to maintain our music collection nicely.
