Beatsource is staying in 1:30min limited mode and won’t allow me to login
“Login is not currently available”
It’s been like it for over a week now.
Please help.
There’s a fix in this thread that might help you:
in my MacOS montery 12.4 , i just updated today Djay pro software from app store to the latest version and cant login to beatport anymore, when clicking to login to beatport button, it does nothing. my beatport subscription is obviously active. I have a live play on Monday and my set relies on both beatport and soundcloud. Please check and fix asap.
Actually, the suggested fix looks like it’s for MacOS not iOS.
Open finder → GO tab → hold down the OPTION key and the Library option will show → navigate to Containers, Djay Pro AI, Data, Library, Application Support, Djay Pro AI, Beatport
Delete the following file:
u.txt
There should be another (or multiple) folder labeled just numbers ex:1535033, inside that folder you will find 3 files to delete:
u.txt
i.txt
r.txt
You should have at minimum deleted 4 files, if there are more than 1 numbered folder (ex:1535033) then repeat the process to delete th…
Thanks buddy! It’s weird as the problem isn’t Beatport it’s Beatsource… no option whatsoever to login. Fingers crossed they get a fix before the weekend.
