the fact is from what warren has said algoriddum have not even physically spoke to apple about this problem which pretty much sums it up, it’s been going on for ages surely you’d be on them straight away trying to sort it out. just shows they really are not that bothered about this at all. after being asked several times warren just ignores the question “is there a predicted time for an update?” and what the fucks going on?
I’m not personally having a go at you warren it’s just been going on for ages now and it seems like not much is being done about it maybe I’m wrong it’s just annoying not being able to use what we’ve spent our money on!
I appreciate you taking the time to explain the situation to me and you can obviously understand our frustration seems like this has been going on for ever.
And Apple says there is no problem with the IOS6, so?
Hi guys, I don’t know if I am lucky or if it’s a question of days before the problem to come back but a week ago I removed the app from my IPad and went to App Store to re-open it (it was a cloud instead of buy or free) and since I did it I never had the problem anymore. I use for 5 gigs and nothing happend. So if few of you could try it to see if it’s only because I am lucky or perhaps some kind of solution…
I don’t say it’s the solution to the problem I say it worked for now.
I got the same problem with a Samsung phone, I had to remove and re-open all apps after some update …
I have old version of firmware, perhaps that’s why it’s ok
Yes but the fact is that it’s not the solution to change all our track to AAC (aple music support), because if u play on both support all the market sells music on wav or mp3 and probably iTunes Store as Mac business will be on AAC also… That’s out of mind one more time from this company… I already change my computer and phone to Samsung and I think I am done with all Mac products
Exactly the problem appear when u mix and wich update u got?
I play 4 or 5 times a week and since 2 weeks no more problems… I just keep for now the firmware original on the Ipro numark and with the last IOS update it’s good also. Few people have also problems with Traktor app, so it sounds more complicated than we are thinking…
Mine is working perfectly since 2 weeks after removing it from my IPad and doing new installation, no more problems even after new iOS update…
I update with the new one I had no problems before and 3 days ago it freeze so now enough I went to buy the Traktor app and it’s amazing and working perfectly and much more better…
Any chance that this long term issue is solved by the release of IOS 7?
Since the issue have been reporter by Algoriddim, maybe the solution is close?
Maybe anyone have installed the beta version and tried???
hey “wise guys” coverts to AAC format, problem solved…
Do these problems only occur with iOS 6? Right now I am having another problem where randomly (I have yet to pin it to a certain action) the song playing will be very distorted, and from then on out, every other song I load up is also distorted. Until, that is, I close and reopen the app (double tap, hold, and hit x, reopen). I am using IDJPro with an Ipad 1, which cannot get iOS 6 that has both an updated app and updated firmware. I was thinking about jail-braking my ipad to allow me to update the iOS to 6, but it seems like there are more problems to come doing that? I have not ever gotten the ‘Song will not load’ error, but this problem I am having is still restraining me from using this outside the home.
I want whatever is most stable with my Ipad 1 (since it is 64 gig and my Ipad 2 is only 16 gig. I need the extra space for music collection). I would like to use this for small events, or even a backup system at weddings and larger events. Is anyone having success with a certain iOS version, DJay version, and IDJNow firmware version? Right now I am on iOS 5.1.1, DJay 1.6.3, and IDJNOW firmware 1.2.1
Tom K
I would like to try out your solution and just wondering how could i go back using an older version of iOS on iPad.
I am having this problem.
When will it be fixed??? This is seriously frustrating.
paying customers waiting!
Just purchased a new iPad 3 32gb today got home thinking yes gonna have a good mix on djay like I would any other day on my iPad 1 through my numark Idj pro to find everytime I go to have a mix an error comes up never happened to me before I thought the newer the product the more things u can do and less problems u would have I’ve just been proved wrong hope its sorted soon, as I’ve just wasted a lot of money plus had to sell old I pad to fund this one not happy
