Could it be that your information is not showing properly in iTunes, as not labeled in the proper places? Is Manchester United cover art or is that your home screen?
I haven’t seen what you are experiencing. But I get what your saying.
If you do a google search for Music app crashing 320kb iphone and set the search criteria time to past month, you will not find anything or anyone complaining about it. We are talking hundreds of millions of people. Add the others with ipad and ipod and you have a huge number of users all with iOS 6.1.
The only complaints that I see is the crashing on Algoriddims site with people using DJay. There are thousands of posts on Apple forums for lesser issues. If this was an Apple issue you would see a huge amount of posts about it.
@Richard Pearce: Because there is no problem with Apple to deny.
So I am confused. Is this a Beatport, Apple or DJay issue?
I am having the same issue only I can’t play any tracks. I have deleted and reinstalled the app several times. All software is up to date. I keep getting OSStatus error 12178
I am getting an osstatus error - 12178 when trying to load tracks after the new ios update, i have a live show saturday, need help asap
Osstatus error 12178.
I have solved the issue, once you load the song once and it shows the error, restart the app and reload the song until it loads properly without an error. Once you have loaded a song without an error it will not have the error again
are you guys using the idj pro? I have been playing a few hours now with no issues after getting every song to load ok once
This has taken quite sometime to fix, playing anything less than 320 kbps is not an option in any club setting. It seems like a lot of people here are using this in clubs, just as myself. I am waiting to play sxsw here in austin in a few weeks, but I cant commit with faulty gear. An update on the time frame we are looking at would be greatly appreciated by everyone so we can plan accordingly.
This issue seems to be ongoing, I updated ios7 and app today, and first track from Beatport gets osstatus error 2003334207, app freezes for a second and starts playing again as usual. How has this not been fixed in a year!
Make that 2 out of the first 4 tracks, osstatus error 2003334207 followed by osstatus error 12178, looks like we are stuck playing songs at 256 kbps
Same problem,…
I reinstalled Djay (and lost all the tracks analysis), resynced all my library, verified the last version of iOS (6.1), tried in or out my IDJ Pro…
It’s happens always the same problems…
For me :
.mp3 320 kb/s
.m4a 320 kb/s
All bought on Beatport or itunes…
Not work for me…
For everyone, if you need to temporarily save yours Dj sets, you can convert your songs from beatport (those who do not work) to an other audio format like AIFF.
It 5 times bigger, but it works…
I’m sure algoriddim developers will fix the issue asap
True, i’ve hundreds of songs to… but, if you prepare a set, you dont need all of them.
I saved a 3H set in converting hundreds of songs… it took me 1h of converting…
And there is a last problem with converting, when you import new files to itunes and Djay, you loose all the hot cues…
Because the apps doesn’t work with 6.1…
Because i can’t do live set without encoded all my library in AIFF…
Because i don’t have enough money to buy an other ipad with 6.0.2…
Because i wanted to try… i install 6.1.2
SAME ISSUE
Hi everyone,
I follow the issue since the beginning… I confess that i’m waiting that the issue is solved soon…
I heard some feedbacks about the Traktor app. So, i spend 18€ in it to try it…
Ok, there are cools features like FX or dropbox sync… But some songs can’t load (the same as in Djay), the app close herself on some multitouch mouvment… Is really not as cool as every one says…
I can understand that some of you are frustrated… But trust me, wait until the issue is solved. Djay (and iDJ pro) is much more powerful…
Hey,
I’m pretty sure that you (Algoriddim) have specials contacts with Apple…
A big apps like Djay must be well known by the apple…
So, could you tell us if Apple understood the problems ?
Do you speak with the other apps editor like Native Instrument for Traktor ?
