I also tried the combination of FLX10 and Djay pro yesterday. Most of the problem areas have already been reported by users. At the moment, unfortunately, I don’t dare/don’t want to do parties with this combo. Hope you can fix these errors soon.
According to our engineering team, the sound color FX should be working as intended.
Could you please share a video with us showing this issue in action?
Please note that similar to other pioneer hardware, a sound color effect will initially not be selected. You will have to press the appropriate button to select your desired effect first.
Hello, I don’t know what exactly I should do? I set the control to channel 1, for example, and then I press one of the Sound Color FX buttons and nothing happens.
@Slak_Jaw@NathanielAlgo
hello slak_jaw, Hello Nathaniel, I had extreme difficulties with the Crossfader fx → Neural mix transitions on Saturday. I wanted the bass to be a bit weaker and turned it down, but with every transition the EQ settings were reset. Is there a solution for this?
The worst thing was that in the middle of the set the second deck froze, with every track playing with echo. So even after reloading a track on deck 2 the echo was still there somewhere and I just couldn’t get it out. That was really rubbish. What is going on?
The software on the iPad also kept freezing, so that I could no longer use the software on the iPad. It only worked with the controller. Please guys, that wasn’t the case with version 5.16 either. What did you do with 5.2?
It’s unfair to compare virtual DJ to a small company like Algoriddim. When they get a bigger team I’m sure they’ll make mappings a priority. Anyways FLX10 is here now,
