Hi @DJKamyR, please navigate to djay Settings>General>SONG LOADING and make sure Reset EQ, FX, Tempo is OFF.
The software on the iPad also kept freezing, so that I could no longer use the software on the iPad. It only worked with the controller. Please guys, that wasnât the case with version 5.16 either. What did you do with 5.2?
Hi @DJKamyR, can you please create a new topic for this and share all the details about your setup as requested in the new topic template. This will really help us to properly troubleshoot this issue with you.
In the new topic, can you please also try to capture a video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
Ok i have not find that Option âŚsearch again
@Slak_Jaw
It doesnât work that way either. The software simply overwrites the hardware settings.
unfortunately not can you show me how it works at your side?
Thanks for the video @DJKamyR. Which CFX type are you using?
Iâve tried them all. I mostly just use vocal cut and vocal sustain
@DJKamyR, please note that some of the CFX types will automatically adjust the EQs. So, I believe this is expected behaviour. I will double check with the dev team to confirm though.
Do Crossfader FX work with the DDJ-FLX10? Also, do the stanard pioneer beat effects work on the selected channel when using Djay?
Come on guys, there has to be a way for me to use the crossfader FX and keep the controller settings.
This really canât be that difficult. Just set a parameter when the hardware controller is turned, then please do not overwrite it with the software.
Thx
Yes it does. try out and let us know
Thanks a Lot ! I fix it. Great !
I have not figured out how to use the hardware beat fx yetâŚ
select your channel where your track is playing, press the Release fx button and then turn the Level deepth knob and set your effect. voila
But that just activates software fx in djay. Been using pioneer gear for 15 years so I know how to activate it ![]()
As soon as you use the DJ pro software, everything is done via the software. Nothing runs via the controller alone.
This is all my Point the Beat FX, via the Software Sounds very Bad
Yes I see thats whats happening, but the DDJ REV 7 I just sold was able to use the hardware FX, so I dont see why it should not be possible on the FLX10 as well.
Mac Desktop,
iâm always compressing the app before updatingâŚ
that way i can go back.
