Thanks for the update to v5.2. I guess this thread is redundant now…
Is there a new update? I can’t find anything in the App Store.
@Slak_Jaw
Could you please reply to this request?
Thx
There is a new update, we now have compatibility. I would see if your device has the latest update too.
Where We Got the Update? I don’t have it
I had to go to the app store, click on my profile. Scroll the page down so it refreshes the page and then update all.
This is IOS by the way. ![]()
Hi everyone,
We’re happy to announce that in today’s v5.2 update for djay on Mac, iOS, and Windows, the FLX10 is now supported.
For more information, please click the link below.
Have a nice day!
Displays don’t work…
- is there a chance that this will come in a new update? Is it run in Midi or hid mode? Is the Master Fx working?
The Sound Color Fx doesn’t work
And the Beat FX for ex. Slip Roll sounds very very bad
And unfortunately no Display Support
Thanks ! for the Compatibility. But I have one Issue. When I put the Fader Down or I Use the Crossfader, the Cue goes on. Its on …
Have you upgraded to 5.2?
Auto Gain, also doesn’t work
If you turn on auto gain and Auto Limit the Second line is extremely louder than other One
I need a Quick-Update for the Weekend please?
Otherwise how can I downgrade my Version
I think it is a feature. On my Old Pioneer SX i have the Same.
Yes I have the new Version , on IOS and WINDOWS and I have the same Issue.
What can I do?
Auto BPM, also doesn’t work
Have you checked your settings to see if you have this feature enabled?
There is a setting where you can trigger the start of the cue with the fader
@Slak_Jaw
@algoriddim_algoriddi
Could You please Check the Points which I Pointed out
Following as I’m thinking of buying the flx 10
Best Controller ever
I totally agree with that.
