@DJKamyR, hey, here’s the built-in mapping for my DDJ-1000. Hope that helps…
Pioneer DDJ-1000.djayMidiMapping (444.7 KB)
better :
Thank you very much.
And does your on jog display work on the ddj1000?
My unofficial mapping FLX10 : (Work on MAC and ipad)
DDJ-FLX10-V8.0.djayMidiMapping (262.3 KB)
The FLX10 USB routing audio FX are SOFTWARE FX in REKORDBOX and VIRTUALDJ not hardware
Algoriddim need to add and emulate this Software FX that Rekordbox and VirtualDJ emulate ![]()
COLOX FX :
SPACE
D.ECHO
CRUSH
NOISE (that work without audio playing - it’s really missing in DJAY pro)
**BEAT FX :
MOBIUS
SPIRAL
ENIGNMA JET
STRETCH
ROLL
SLIP ROLL
Low echo
and add a master software FX section like Rekordbox and VIRTUALDJ
and add HID command for FLX10 ( they have HID command for CDJ 3000 why not for FLX 10 and XDJ-RZ ?)
Please Algoriddim take a look at VirtualDj that emulate all pioneer BEAT FX and COLOR FX , beat and Color and send sem via HID to FLX10 even the BEAT FX display ![]()
Hi, thank you posting a new mapping.
What is new in this rls?
No, the jog displays do not work on the DDJ-1000
ALGORIDDIM PLEASE……What do you need for this, a donation? I think we are all willing to make a donation if you start directly with HID and what els ist needed to have the FLX10 work 99-100%!
HID is noit enough to make FLX10 100% compatible in DJAY PRO
FLX10 beat FX and COLOR FX via USB A and B are not hardware.
FX are software based and only Rekordbox and VirtualDJ emulate all the FX for the FLX10 (Perhaps DJAY pro in future after V5.1.4 ?)
Algoriddim need to add Pioneer FX in their FX :
COLOX FX :
SPACE
D.ECHO
CRUSH
**BEAT FX :
MOBIUS
SPIRAL
ENIGNMA JET
STRETCH
ROLL
SLIP ROLL
Low echo
And the big Color FX missing in DJAY pro is noise FX that work even if their is no music. a good noise FX like DJM / Rekordbox / VirtualDJ noise FX.
Slak_Jaw Please bring this up to the CEO
ALGORIDDIM PLEASE……What do you need for this, a donation? I think we are all willing to make a donation if you start directly with HID and what els ist needed to have the FLX10 work 99-100%! Please look at VirtualDJ everything is fine in VirtualDJ. Every single Button, LEDs, Display ect. ect.
PLEASE PLEASE PLEASE
Hi @DJKamyR, thanks for your continued enthusiasm for this hardware. I have forwarded your message onto the dev team.
Seems like I am going to abandon Algoriddim for another platform as I am not going to abandon my FLX10. It’s a great controller that works well on the other “big” 3. What a shame and honestly disappointing. Over a year and not a single word. Tells me there won’t be any implementation soon.
You made my day…… thank you
You’re welcome @DJKamyR
In general, please open a new topic as this one is about DDJ-FLX10 compatibility. But in your case, it might help you to know that there’s a known issue with 5.1.5 that should be fixed soon: Local Music not working on iOS djay 5.1.5 - #34 by Slak_Jaw
Hopefully support for this controller will also include its DMX connectivity and light management over Djay Pro ![]()
However I guess this is supported by some sort of proprietary driver which will probably only work on Mac/PC.
I’m not aware of any existing USB DMX Class Compliant norm for this to be supported without driver or through iOS / iPadOS ![]()
I really hope that you will also listen to users with the WIN operating system. I am waiting to connect the FLX-10 to the WIN op system.
I just got the trial demo and love the software much more than traktor and rekordbox. However, I’m waiting for flx10 support before I commit to djay pro (OS Sonoma).
What do you mean? I’ve been using Djay Pro 5.1.6 on Sonoma for months now.
