Update to 5.4.2.
No longer in trial mode, nought the full version to rule that out.
Still doesn’t work, DJAY 5.4.2 asking me to update my firmware, even though I have the latest firmware.
Still not working for me, what do you need to diagnose this?
Good day Members. . Can the Colour Fx on the FLX 10 be changed when using DJAY. Thank you in advance.
No I don’t believe they can be changed.
Just subscribed to pro now. I enjoyed djay and decided to go back. It does change one of the 3. However it does not save upon reopening djay.
Really? Still asking me to upgrade my FLX10 and no answer after I’ve paid for the software.
Update to 5.4.2.
No longer in trial mode, bought the full version to rule that out.
Hi @DaMacfunkin, sorry to hear you’re experiencing this issue. I suggest that you backup your djay Media Library database and any custom MIDI mappings, then uninstall djay, reboot your device, and reinstall the latest version of djay. You can find the files above in the following locations:
- iOS: using the Files App, navigate to Locations->On My iPhone/iPad->djay->User Data
- macOS: https://help.algoriddim.com/hc/en-us/articles/360014912211-Where-does-djay-Pro-store-playlists-cue-points-and-other-data-on-my-Mac
- Windows: https://help.algoriddim.com/hc/en-us/articles/360014912131-Where-does-djay-Pro-store-cue-points-and-other-metadata
- Copy the files to a new location or external drive before uninstalling djay. After reinstallation, you can simply copy these files back to their original locations to maintain your Hot Cues, Saved Loops, My Collection Playlists, History and Queue.
Still don’t like the fact the digital maker does not snap to the 12 o clock position when pressing a saved cue like it does in Serato……have to use Serato until this is update😡
is anyone else having these issues? Any plans on addressing the performance pads in a future update? using the page buttons to switch hot cue banks in particular would be great to get working.
I’m very surprised! If you use the Automatic Mix the display of the jog wheel works!
yes, this is called “screen saver” displaying dummy information … it is a hardware feature that works without DjayPro
Screens unfortunately do not work with actual information on IOS Djaypro in normal mixing mode
I hope Algorridim is working on it as this obscure “missing IOS HID” functionality (?) seems to be available with other software companies according to google search…
Thank you very much and we hope to receive a new update so that we can make full use of the device with Djay Pro. Have a nice day
Hi @Djay1 welcome to the Community! Thanks for the info regarding “screen saver mode” @turbopussy. Regarding screen support on iOS, this requires HID which is currently not supported. Thanks!
10 posts were split to a new topic: FLX10 FX and Hot Cue issues (iOS)
It’s the flx10 with the MacBook
Hi @Five-0, I’ve moved this discussion to its own topic:
Hi, I tried this so many times, is there a list of reg settings I can delete or do you provide a total uninstall feature for this app, it is obviously referencing some dodgy registry info.
Hi @Slak_Jaw , I noticed a big difference with the official FLX10 support in djay Pro — particularly the fact that when activating an effect, for example Echo 1/2, using the main effect knob on the controller, we no longer need to turn the knob all the way to the end of its range to get the echo effect to 100%. This behavior felt quite unnatural for a Pioneer DJ/AlphaTheta product, where setting the knob at 12 o’clock was usually enough to fully activate the effect.
Moreover, the echo effect now sounds much closer to the “natural” Pioneer DJ echo.
I wanted to know if it’s possible to reproduce this same behavior on an FLX4 — having the effect reach 100% intensity at the halfway point of the knob (12 o’clock) and getting a “Pioneer DJ”-style echo. I’m not sure if this was implemented specifically for the FLX10 only, or if it can be replicated on the FLX4 simply through mapping and parameter adjustments in djay Pro?
Hi @DJCroustibat, please make a new suggestion topic for this. Thanks!
From Reading posts, I understand there has been an evolution of the integration with DJAY for the flx10.
I’d like to understand what the current state of the software effects is. I had a quick play with a unit in store and I can see that djay shows the pioneer effect names which are not available for general users. The effects sound similar to The pioneer versions.
Are the current DJAY software emulations based on existing effects in DJAY or are they actually licenced versions of the software effects from pioneer?
They are based on existing djay FX.
