Djay 6.0 dream features?
I don’t know if it’s already been said but I’d like to have a compressor on the master in addition to the limiter, or a compressor on the channel so I can raise the level of those 60s/70s/80s songs that have a pitiful mastering. :folded_hands:t2:
NOTICE: As this topic continues to grow, I think it’s worth reminding everyone again what I shared above multiple times:
If you want any of these ideas to gain traction with our dev team, you need to post your comments in an existing related Suggestion topic (please use the Search Tool) or create a new Suggestion. This allows other users to upvote your idea and for me to properly track and report the feature to the devs. This is a great topic for brainstorming ideas, but this is not a suitable place for me to gather feature suggestions for our team. Thanks for understanding.
I hope that helps!
I absolutely love the djay pro software but if vdj comes out with a completely independent iPad app and it’s provided under their lifetime purchase(I doubt it) I’d seriously consider giving it a try if not switching over completely
Thanks for the feedback @eyeseeyou01
denodj screen support!!!
Thanks for sharing @giorgos_hatzinikitas
Traktor controllers support
Some traktor controllers are already supported.
only 2 so far, wishing they can support all
Can the iPhone’s vertical screen be rotated 180 degrees?
I don’t think it can on any app
It’s possible on the iPad, why not on the iPhone?
Probably to do with the cameras etc at the top of the phone and the microphone position. It’s always been the case with iPhones, you’ve never been able to flip them upside down, and I can’t imagine Apple changing it anytime soon
Hi everyone,
I am requesting full keyboard mapping support for all djay features. Many powerful tools added over the last few years remain impractical for live use because they require tedious menu diving, mouse navigation, and drag-and-drop actions. Without the ability to bypass the UI with custom shortcuts, these features are effectively useless in a high-pressure performance environment. To make djay a truly professional live tool, users must be able to assign a key command to any feature currently buried in a dropdown or window.
Thanks for the input @Donn
Are you asking if you can use djay pro on an iPhone but with the charging port on the top?
yes, because with the hub the wire has to make a wide loop, with the risk of disconnecting
This is an iPhone/iOS specific limitation.
I’ve used one of these to help with the wire clutter when using the iPhone in vertical mode
Thanks for sharing @eyeseeyou01.
My personal recommendation when using USB adapters and hubs is to make sure you buy from reputable brands with high-quality standards. In my experience, many of these 3rd party adapters are of poor quality and can be unreliable in mission critical scenarios.
