Djay 6.0 dream features?
You can turn off the soft-takeover feature in midi if you go to advanced and move the fader. You’ll see pickup mode checked and then you can uncheck it. With that being said even with it unchecked, I’ve gone to adjust the fader and it’s still stuck. But if I use sync and then disengage, there’s no felt when moving the pitch fader.
I would just like djay to be able to handle the metadata of a track. It’s still crazy to me I can’t have separate cue points for an intro and radio version. Also, I just started using the iPad. This will be for wedding ceremonies and back up if my laptop crashes. One library is awesome, but I wish I could create crates on MacOs and have them show up on iOS.
Here’s a list of features that are currently missing in djay Pro (or not implemented in a “full” way) that I’d like to see in djay 6.0.
  1. iPhone (iOS) support for RANE Performer — full, plug-and-play
    • Full djay iOS (iPhone) compatibility with the RANE Performer
    • Proper audio + MIDI/HID + pad/LED feedback on iPhone
    • A clear “supported on iPhone” workflow (not “works only on iPad/Mac/PC”)
  2. RANE Performer: complete feature parity (no missing UI/feedback features)
    • Full use of all display-related modes and library/browse visuals where applicable
    • Full jog / waveform / stem (Neural Mix) visual feedback parity (where hardware supports it)
    • No “partial mapping” limitations—everything that’s on the controller should be usable
  3. Denon PRIME / SC6000: full screen integration + PRIME-style workflow
    • Denon SC6000 / SC6000M: support for main screen + jog screen style integration (browse, waveforms, deck state, cues/loops)
    • Proper dual-layer deck workflow support with crystal-clear UI + hardware feedback
    • PRIME gear should feel “native” in djay, not like a workaround
  4. True AI playlist curation (beyond basic automix)
    • AI set builder that can create a structured set (warm-up → peak → close) from:
    • Your library + supported streaming sources
    • AI that understands intent and constraints:
    • “clean only”, “wedding”, “afrobeats + R&B”, “keep BPM 100–110”, “no explicit”, etc.
  5. Real “AI next-track” suggestions across sources
    • Intelligent next-track recommendations that consider:
    • energy, harmonic/key match, phrasing, vibe, and genre adjacency
    • Ability to recommend the next tracks from:
    • current playlist, your library, and supported streaming catalogs
    • Optional quick feedback buttons:
    • “worked / didn’t work” to improve future suggestions
  6. Engine DJ ecosystem compatibility (library + USB workflow)
    • Better Engine DJ playlist/crate compatibility in djay:
    • import/export playlists
    • preserve cues/loops/beatgrids/artwork/tags reliably
    • A smoother “show up with a USB and play” workflow that matches how Denon users actually gig.
Just read the thread, great ideas!
I gig a lot with DJP on iPad - Crazy Ai ideas are cool but for me until DJP gives us proper playlist and library management we still have to cover basics.
  • We still can’t re order tracks manually in a playlist in 2026, wild.
  • Playlist jumping means endless scrolling because BPM isn’t retained when switching playlists.
But one library was a game changing update too!
I’m sure this year will be even better for Djs.
If you create your playlists in the My Collection source you can manually re-order tracks.
!!! nice!!! Thanks for alerting me to this, have to press “Reset” at the bottom of the sort options (Added, Album, BPM etc) , if anyone else missed it.
Would make more sense to call it “Sort” or something more relevant, it’s not intuitive calling it Reset.
But great help!
You’re welcome @Mixfit. Yes, the songs need to be unsorted in their default order before you can rearrange them. Happy to help!
I would love to have the option for double digit decimal places in BPM. Eg. 115.15bpm
Tutti questi suggerimenti riguardo all’adozione di funzioni AI sono semplicemente fantastiche e penso che la rotta sia proprio quella per il futuro, si giocherà proprio sulle funzioni avanzate con AI.
Dal canto mio mi piacerebbe avere il supporto allo schermo del Prime GO (come ce l’ha Vdj) e l’integrazione alla libreria di Engine, sì sono un dj che usa Denon :sweat_smile:…del resto sono macchine fantastiche ma il software è rimasto all’anteguerra rispetto a DjayPro!
Poi un’altra cosa che mi piacerebbe vedere è l’autocompilazione di punti CUE come fa Mixed In Key, nelle varie fasi della traccia (drop/verse/ecc), potrebbe essere utile per quelle tracce che non mettiamo spesso o quasi mai ma almeno ci sono i punti CUE pronti nel caso ci servissero.
Per il resto penso che sia un software formidabile per le sue performance e la sua modularità multipiattaforma.
Roland DJ 707M support
would be nice to have some stored settings with VSTs
All Roland controller support.
Simple: recursive subfolder music listing.
After spending a weekend mapping my Roland DJ-505 controller, there is one thing that would be nice to have; customisable midi actions for things like long press, double tap of buttons and also to have midi out options for things like creating flashing buttons for alternative modes.
One other thing I would appreciate as well, would be to be able to zoom out more on the waveforms in Djay. Particularly on the iPad app.
NOTICE:
The great ideas continue to flow in this topic. Thanks for sharing everyone!
Just a friendly reminder however - if you want any of these ideas to gain traction with our dev team, you need to post your comments in an existing related Suggestion topic (please use the Search Tool) or create a new Suggestion. This allows other users to upvote your idea and for me to properly track and report the feature to the devs. This is a great topic for brainstorming ideas, but this is not a suitable place for me to gather feature suggestions for our team. Thanks for understanding.
Yeah. That would be great.
Wish these buttons could be moved under the decks and not in this tree . . Just feel they are that important
A option to show this under the deck in place of beat jump
Everything is very simple.
Djay Pro needs to do what we asked here to do in 2024-2025. :rofl:
What kind of AI are you talking about here if I can’t see the entire program interface if I open the program window to the full wide monitor format (3840x1600)… :joy:
I would like to see automatic ai hot cue settings at chorus verse and intro or outro
