we are sorry to hear that. So after successfully updating the Mixtour now the controller is not powering? Can you check if the controller is being identified by the iPad with a midi signal app like “midi wrench”?
Thank you in advance and we are sorry that you have to go through this.
can you please check if the firmware was installed correctly so we can gather all informations about not working updates and send them straight to Reloop.
You can check if your controller was updated correctly by connecting it to your iPad. Now…
open the iPad “Settings”
go to “General”
click “About”
scroll down till you see the name of the attached controller
click at “Mixtour” (for example)
now make sure V1.07 is being displayed as firmware
Thank you, just want to make sure if the update is the problem or the updater.
thank you for the follow up. Can another user confirm this, would be very interesting to get further information about this issue.
Can you reproduce the issue and make an exemplary video? That would help us tons, thank you very much you can send the video to support@algoriddim.com (or use an file uploader like we transfer and send us the link).
That is bad news, can you contact us via support@algoriddim.com so we can gather all your informations and send them to Reloop? Please attach an image of the devices firmware.
Thank you in advance, we are sorry for the inconvenience.
If that is the case it looks like an hardware issue.
Could you please contact the Reloop support and tell them that your Beatpad is loosing connection even though its firmware was updated.
Hi Jose, I am having the same disconnection issues. How did you downgrade the iPad IOS to 9, not found a way of doing that successfully yet. Hope you can help? byardt@gmail.com
Hi, yes I have, three times also re-installed the iPad IOS 10.2.1 twice and still getting connection failure from the Beatpad2?
Can you help?
Thanks in anticipation.
Hi Lukas,
It is my Beatpad2 that I am having the problems with. Mixtour user are having the same issue.
I have updated the Beatpad2 firmware to v20.09. I have reinstalled the IOS 10.2.1 twice now and set my iPad Air 2 as a new machine, ie (not importing old settings) and still the Beatpad2 drops the connection after five minutes or so?
Opened midi wrench and turned on the Mixtour. The device seemed to be sending midi signals to the iPad.
Opened djay and began playing a song. Within a minute the song cannot be heard through the Mixtour and it no longer controls the app. It seems to have disconnected.
I immediately go back to midi wrench and the Mixtour is no longer sending midi signals to the iPad. It is shown as offline.
Before I upgraded to iOS 10, djay and the Mixtour had no problems. It’s obvious that upgrading was a mistake, but is this an issue that can be resolved?
