DMX lighting control Support
Add new features support for dmx lighting control on app
Hey @Cooljackdj
Thanks for your suggestion!
DMX control in the djay app isn’t currently supported.
However, we’re looking forward to seeing how interested other people are interested in this feature suggestion as well.
Have a nice day!
Hey, I’m interested, for sure. This would be great for everyone DJaying at house parties, where you don’t necessarily have someone for the lighting. I actually have developed a quick concept of how that could be done some time ago, shouldn’t be too much code to implement (except for the UI, where entirely new components are required).
Hope this may bring back attention to this topic, as this was already mentioned on the old forum.
Have a nice day!
check through the stuff posted here about sound switch. it works - I use it
only thing that now lets down djay for this is not being able to set different bpms for different parts of tracks which vary - unfortunately for me the genre that I am most using does that a lot
Hey @jbohnst - These are some great ideas. Thanks for sharing this!
and @Paddy_Callaghan, thanks for pointing out the content from other users posted about Sound Switch!
We appreciate your input on the topic :smiling_face:
Hi Algoriddim staff , How many user requests for DMX support do you need before something going to happen?
A quick search in forum showing that this DMX topic has been requested for several years now.
thanks, Emil
Hi Guys,
i arrive to Djay one year ago from Denon with Engine sw. The most easly implementation of dmx could be from soundswitch.
The same integration with engine to djay collection and using usb dmx dongle of soundswitch for me could be a Goal.
Carletto Dj
My interest here is varied automation with minimal input and no song-based preprogramming. A minimal need for triggers during a set of preprogrammed effects is ok, but still don’t want to do that much. I want lights to just do stuff even if it means repetition and less interesting result so music is focused on. I know a ton of cheap and expensive gear available has “sound detection,” but that is extremely tired and basic and barely reacts to music with no choreography at all. I’d love a smarter and more capable automated system.
Sound Switch seems interesting DMX controller scheme that’s more traditional in features and use. It’s not too expensive at $300 for small control hardware but requires software subscription too. Needs either a separate computer with USB out to its Control One hardware interface or Denon DJ decks with “engine dj” compatibility. This is more traditional approach with a mix of preprogrammed/automated/manual control on a hardware control surface.
MaestroDMX seems to be a new kid with an all-automated “AI” approach via a single hardware box with RCA audio inputs and DMX out at $750 (no computer or external beat-clock soft/hardware needed). Claims to simply work in real time lighting animations/effects using live sound with AI to dissect audio for intros, builds, drops, transitions, outros, etc. Demo videos are interesting though it all seems fairly repetitive and simple. Still, it seems to make discernible changes to music. Can’t tell how well it can control all kinds of different DMX lights and their capabilities (the videos only show static “par light” LEDs that flash/change color and “moving head” LEDs that change color). Requires an Android/iOS app to configure which may allow extra control during a set on the device too.
Couldn’t find much else. Pioneer / Rekordbox have solutions that are strictly tied to their world, but they seem expensive, traditional in approach of preprogramming, and too locked in.
I would love to see native DMX control across all platforms of the app.
You could run a usb hub w/ hdmi out off a phone/tablet and connect your micro-dmx adapter and voila.
The idea is connect your controller/mixer, connect your hard drive, connect your dmx controller and connect HDMI for video output.
The ideal and universal solution would be to place an unlimited number of light cues in your tracks that trigger MIDI or OSC commands. Additionally, if you could interpolate the MIDI/OSC values between light cues, you would have the perfect solution for controlling any VJ software. These light cues could be synchronized via iCloud, just like regular cue points.
Furthermore, the OSC protocol can be used in a network, allowing you to trigger controls on another computer.
Apart from the light cues, OSC can be used to monitor or, where useful, control parameters such as the location of the playhead in beats/bars/time, the position of your cue points or loops, samples, and the status of various effects.
I think fully integrating light control into the djay app would make it unnecessarily complex. Moreover, the implementation would be either too limited or too extensive for many users.
I use Lightkey (lightkeyapp.com), Visual Synthesizer (Visual Synthesizer for Desktop and Mobile - VS | Imaginando), Resolume, and TouchDesigner to control my visuals.
It would be great if the developers of djay and Visual Synthesizer or Lightkey could work together for a closer integration.
This universal connection with VJ software seems like a good answer to the Pioneer Pro DJ Link concept.
Kind regards,
Steve
Dear A-Team, :slight_smile:
Please focus on the independent implementation of already fully described open interface standards such as MIDI (MIDI clock as a must!), OSC, O2SL, …
The provisioning of “necessary” control messages should be the core feature of Djay. “Must haves” first. “Nice to haves” second.
In my opinion, probably the OS2L spec gives some orientation on what are “must have” features for a DJ.
Please don’t try to implement things that other softwares are doing already really good or even top notch.
Best regards,
Ben
I’m here and interested in DMX and/or SoundSwitch compatible features. I’m really just making this comment in order to keep this thread open algorithm. Please consider DMX lighting control as another upgrade to the software. As an event DJ over the years lighting has been a very important items that are part of my workflow. I’m sure I will find some work arounds per the thread above.
Hi @PhiMobileSounds, welcome to the Community! Thanks for the additional input.
hey amigos yo lo consegui muy facil.
simplemente duplique la señal master y la introduje al qlc+y en qlc+ programe el show completo.
Por cierto tenia una impulse 300 sin uso y la mapee para disparar escenas con qlc+
chao y gracias
Hey friends, I got it very easily.
I simply duplicated the master signal and introduced it to QLC+, and in QLC+ I programmed the entire show.
By the way, I had an unused Impulse 300 and I mapped it to trigger scenes with QLC+.
Bye and thanks.
Hi @MIQUEL_Velasco , welcome to the Community! Thanks for sharing this.
Hey y’all.
We want to level up performances. One method for this is lighting. Takes music to another level.
Djay Pro integrates with Ableton Link. Link integrates with some lighting tools (such as SoundSwitch). Great. But this only gets us so far. Link has certain problems (when songs have tempo changes), especially since Djay isn’t considered the “master” for tempo sync.
Curious, what are you doing to solve your lighting challenges?
Djay Pro team, are you thinking about these topics? Would love to hear more from the community as DJs look to deliver the best live experiences with Algoriddim being a major part of the equation.
Hi @gizmo, I’ve merged your new topic with this existing one as I believe they are closely related. Regarding Ableton Link:
  1. The current behavior of Ableton Link in djay is: When you turn on Ableton Link and there is another software that is already running Ableton Link, djay will sync to the other tempo.
  2. If you turn it on while there is no other software, it will keep djays tempo. If you then turn on Link on the other software, the other software will sync to djays tempo.
  3. So, we recommend that you turn Link on in djay before you turn it on in your lighting software.
I hope that helps!
Thanks @Slak_Jaw that is helpful context. I’ve been testing this and run into a situation which, based on your instructions, is causing some confusion.
Check out the video for more specifics.
  1. Djay is opened
  2. Ableton Link is enabled from Djay
  3. Lighting program is turned on
  4. Ableton Link is turned on within lighting program
The music I typically Djay can have tempo changes, like the one you’ll see in the video. The song speeds up to match the Ableton Link tempo rather than adjust the tempo to what Djay is feeding it.
Hope this assist provide more context, thanks!
You’re welcome @gizmo. Thanks for the video and details. How do these tracks behave when Link is turned off?
SoundSwitch works with Serato, Virtual DJ, and Engine DJ. With all the great features Djay Pro offers, the lack of SoundSwitch integration and the ability to timecode and script DMX lighting feels like a big missing feature.
