MacBook Pro (14 inch, 2021)
Chip: Apple M1 Pro
Memory: 16 GB
Mixer: Pioneer DJM-S11
Turntables (DVS, Relative): 2 x Pioneer PLX-CRSS12
Hello! Using Djay Pro 5.01 with the above setup and leaving the “Exit sync on pause, scratch, or cue jump” setting unchecked, sync is still exited on a scratch, cue jump, or pause. I’m not sure if this is the intended behavior when using DVS, so I thought I would report it.
Please let me know if you need any additional details. Thank you!
@djcoldswitch@Baro@Martial_Autist are you running the latest 5.0.2 version of djay Pro? I believe this bug was addressed in the latest release. If not, please report back and let me know. Thanks.
sync keeps cutting off when mixing tracks are analyzed i can beat match so don’t want to hear cut off sync!!! Before update no problems, tried straight and dynamic sync switched from bpm and bpm and tempo same issue before update no problems
I use beat jump constantly and if I beat jump forward it stays on, but if i beat jump backwards it turns sync off. I also know how to beat match so please I don’t want to hear it. I primarily use it for bpm but because of the dynamic beat grids it also changes the bpm of the incoming track after I have set it. It’s really annoying. I now have to hit sync every time I beat jump backwards.
I have a problem with the sync.
As soon as I play two songs that are synchronized and I touch the turntables on the controller, the sync goes off. This only happens with the update to 5.1
Can someone help me so that this doesn’t happen?
@djcoldswitch and @Baro please note that if you want Sync to remain ON during these actions that the setting should be OFF. If you read the wording closely it says Exit sync.
@Baro can you please capture a video of your specific issue so that I can better communicate this to the engineering team? Please upload the video to a cloud service like Dropbox or Google Drive and share a link to the file here. Thanks!
