Yes with 5.2
Filter fx as I mentioned
With filter fx as I mentioned in the initial post. I agree it is logical, that is why I am making sure I did not miss an option to allow cue preview pre-fx. I typically âwarm upâ so to speak my scratch in transition before opening the fader however.
This a known issue from 5.0. Pre cue not possible with cross fader effects. Apparently itâs a complex issue.
Yes, working as intended, but ⌠not as expected ![]()
Quick Workaround â map a button to toggle Crossfader FX On/Off.
Yep I have this mapped already as I use Crossfader fx quite a bit.
- Device model *M3 Macbook air, or iPhone 14 Pro
- Version of operating system macOS Sonoma 14.6:
- Version of djay (e.g. 5.1.2): 5.2.4
- Hardware/controllers used (e.g. Reloop Mixon 8 Pro): DDJ-FLX10, FLX4 or just software on its own
Iâve discovered this bug now that iâm using the Crossfader FX more. Iâve noticed that if CFX is enabled, having the CUE on the inactive deck doesnât send the headphones any sound. In order to be able to hear the song in CUE, you have to slightly open the crossfader, but then the audience hears this too!
Fix would be to allow us to hear inactive deck if CUE is enabled for that channel on the mixer/controller without having to toggle on/off the CFX mode each time we want to cue a song.
Hi there, this has been identified from the start of 5.0. Very complex apparently. Engineers are aware of issue. Not sure when it will get resolved though
Interesting. Didnât think it would be complex compared to some of the stuff Algoriddm is pulling off. Canât it send unaltered audio to the inactive channel when CUE is enabled? Effectively disable CFX and send audio with fader down like it does normally? right now I have to turn CUE ON, then CFX off, and then proceed to find a mix-in pointso itâs ready to go then CFX back on then CUE OFF.
Hi @djchase, no pre-curing when using CFX is currently expected behaviour. The dev team is aware of this and is investigating options. However, as @Dysfunk_DJ indicated above, this is not a simple fix. Iâll report back here when I have more news. Thanks.
MacBook Pro 2021 M1
Denon Prime 4
Sequoia 15.3
Thinking of moving from Serato as there are many features that I like, but came up against an issue when trying it out tonightâŚ
I have enabled the crossfader fx as the mixing between songs whilst changing vocal and tempo is so good. This is where I encountered my issue though. When I cue the next song and I want to listen to it, I canât hear anything as the âeffectâ is applied and the crossfader is over the other side. The only way I can get to hear it is if I nudge the crossfader slightly, but then I only hear it with the effect applied, such as only drums or no melody/vocals etc. hope that makes sense!
What I want is to be able to hear the next track ânormallyâ and only way this works is to disable the crossfader fx.
Iâm using a Denon Prime 4 by the way.
Hope someone can help!
It seems youâve answered your own question. If youâve engaged the effect and then completed the crossfade - turn off the effect. Engage it again when you next need it.
Hi @Stuart_Cox1, PKtheDJ is correct. If you want to pre-cue the other deck in your headphones, you need to turn CFX off between transitions. I hope that helps!
- Hardware/controllers used: Pioneer DDJ FLX 10
Summary of the issue:
djay Pro Cueing Bug: A Live Gig Discovery DJs Need to Know
Last night, while performing live using djay Pro AI on my MacBook Pro paired with the Pioneer DDJ-FLX10, I encountered a puzzling issue that could have easily derailed the set if not resolved quickly.
Despite everything being properly configured â
⢠Main Output: FLX10 ch 1-2
⢠Pre-Cueing: FLX10 ch 3-4
⢠Mixer Mode: Internal
⢠Headphones MIX knob: Fully set to CUE
⢠CUE buttons: Correctly selected on non-playing decks
⢠Channel faders: Not in THRU mode
âŚI discovered I was unable to preview non-playing tracks in my headphones. No matter what I cued, I kept hearing the master output. Everything looked right, but cueing simply refused to behave.
After double-checking every possible hardware and software setting, I eventually uncovered the culprit:
The issue was caused by djay Proâs âCrossfader FXâ being enabled.
When Crossfader FX is toggled ON, it overrides or disrupts the normal cue routing â effectively disabling pre-cue monitoring, even when all headphone and mixer settings are correct.
As soon as I disabled Crossfader FX, headphone cueing was restored instantly and worked as expected.
Why This Matters:
This is clearly a software-side bug or unintended behavior, especially critical during live performances where cueing is essential. DJs may not immediately suspect a creative FX tool to interfere with such a core function.
My Suggestion:
Algoriddim should investigate and address this bug. Ideally, Crossfader FX should not affect headphone cue routing, or at least there should be a warning or setting to manage this dependency.
For Fellow DJs:
If youâre using Crossfader FX in djay Pro and find yourself unable to preview upcoming tracks â toggle it off immediately and test your cue. This might save your set.
Stay sharp⌠and keep the dancefloor lit.
â DJ Pappy J
How to reproduce the issue:
Hi @Jacko, please use search before creating new topics. I have merged your new topic with this existing one. Thanks for the detailed information and work around. This is a known limitation with CFX and our engineering team is already aware of it. Thanks again!
- Version of operating system (e.g. macOS 15.6.1 ):
- Hardware/controllers used (e.g. Pioneer DDJ-FLX4):
Your question:
On two separate Mac Book proâs both running Sequoia 15.6.1 (24G90) and DJ Pro 5.4.2 using my local music library and using Tidal, also using a variety of controllers, I am having issues with no signal in the CUE feed and sometimes no signal to the channel out at all. If I turn off Crossfader Effects the problem is gone.
Hi @DJDave64, welcome to the Community! Please use search before creating new topics. I have merged your new topic with this existing one. See above for more details, but TLDR, headphone pre-cueing is currently not supported with CFX. Please turn it off when you need to pre-cueing in the headphones. Thanks!
- Device model (HP spectre):
- Version of operating system (Windows 11):
- Version of djay (5.2.4):
- Hardware/controllers used (DDJ 400):
Your question:
I noticed this Saturday that when you activate the crossfader FX to âneutral mixâ or any of the other options. You cannot hear or cue the next song from the other deck. No sound comes from the deck to cue to the next song. Could you please check it. Thanks!
Hi @Johnny_Q, please use search before creating new topics. I have merged your new topic with this existing one. See above for more details, but TLDR, headphone pre-cueing is currently not supported with Crossfader FX. Please turn it off when you need to pre-cueing in the headphones. Thanks!
Is this being work on or itâs just not possible to be implemented?
Hi @Kevnice, we donât have any news to share regarding this.
