Hercules Inpulse T7 support
You’re welcome @Raymond_S
Can anyone report on the accuracy of the official mapping in the new 5.2 version?
Been meaning to grab a T7 for a while, but wanted to know if the jog’s are spot-on, with no drift/latency etc. when scratching, or if there’s any other issues with integration with DJay?
I tested it, and it feels more accurate then rane one.
Rane one feels better on serato then djay pro.
But Hercules for me it feels better on djay pro then serato.
No Drifts so far detected.
I tested this on MacOS
@NathanielAlgo @Slak_Jaw
Every Algoriddim team member needs to watch this video from Phil Morse at Digital DJ.
He gives some amazing feedback, and I can even quote him as saying “this is the best DJ software in my view”
Every member of the Algoriddim team could take something away from this video, to drive Algoriddim to even greater success.
Everyone is rooting for you guy’s… we’re all sick of the Pioneer/Alpha-Fetus domination.
If we must have a Pioneer/Alpha-Fetus setup in every club and venue in the universe, let’s make it so DJ’s can just plug in their Phone/Tablet/Laptop into any setup, and seamlessly mix into the previous DJs last tune.
And here’s the dream…The next DJ plugs their Phone/Tablet/Laptop into the setup, and Djay software links and syncs the two devices so the DJs can once again seamlessly handover to eachother (Ableton Link might be a good standard for manufacturers to follow)
This is how you will takeover…when DJs realise they’re not handcuffed to Rekordbox!!!
I wish you guys all the best.
:facepunch:t3:
https://www.youtube.com/live/67JQHQkcZ5s
Yoooooo!!! This sooooo great! Words cannot express my gratitude to the staff at Algoriddim. So excited to rock my T7 and DJAY Pro. Thank you Thank you Thank you! Videos to follow!
You’re welcome. Thanks for the positive feedback @Terrence_Lewis
Last year I bought the T7 with the hope that one day it might be supported in Djay Pro. I am so appreciative that the Algoriddim team listened.
So far I’m loving the update!
Finally, thank you so much guys. I been testing my t7 with the ipad and runs well, need some updates but that is a good start. @Slak_Jaw thanks for the the support :pray:t2:
You’re welcome @Carlos_Gonzalez
Been testing the T7 with the ipad and noticed the stem separation has a slight delay. If I press the vocal button, there’s a bit of delay until the vocals are isolated. Same with the Stems EQ. Im using an M1 ipad pro. I still have my REV 1 and there no noticeable delay with using the stem EQ
2 posts were split to a new topic: Hercules Inpulse T7 Drift Issue
I am testing the T7 with the IPad Version and I have some questions:
  1. Start/Stop delay: I want a longer stop delay when pushing the play pause button but doesn’t matter which delay I set in the setting it doesn’t have an impact ( I can only assume that this is because the motorized platter is in play ? )
  2. the LED on the Browse knobs can blink in the beat tempo but with Djay Pro it just has one static color, is this something that could be added ?
  3. as some know the backspin isn’t the best with the provided mats so I was wondering if the speed of the backspin can be adjusted ( I cannot midi map the wheels so there is no option to adjust the speed) but maybe there is a temporary button that could be mapped to some backspin I saw there is an backspin action in the midi mapping but for me it has no effect
Thank you very much for helping me
Hi @FiNKi, thanks for the feedback. I have forwarded this to the engineering team to see if they can offer any suggestions. I’ll report back here when I have news. Thanks!
Regarding the Backspin, you can MIDI map this in djay to an available button on your controller. First, press the button you want to map on your controller for the Deck 1 Backspin. Then set the Target to Deck 1 and scroll down to the FX Section and set the Action to Backspin. Also, make sure in the Advanced Control Configuration you have the Type set to Button. Repeat this for another button for Deck 2.
Hi Roubo? Are you happy with the T7 with Djay pro? I’m using Traktor controller Mk3, but want to change to Hercules T7. Do you recommend it ?
Thanks!!!
Are you still having the delay with stems on the Hercules T7 on djay? I’m having the exact same issue right now.
Hello everyone, how do I map stems to EQs in DJay Pro with the T7?
Thanks in advance for your help.
Hi @micrologiq, welcome to the Community! The easiest way to use Neural Mix EQs with any hardware is toggle between normal EQs and NM EQs on screen. This will toggle the hardware EQ controls to control Neural Mix EQs with no special MIDI mapping required.
If you’d like to MIDI map this toggle switch to a unused button on your hardware, please see below for the command:
Hello Slak,
Thanks for this quick and detailed response :+1:
Another question: can we map the BEAT JUMPs to the T7?
Ideally, this would be done by holding down SHIFT + the loop dial (like on my Traktor S4 mk3). Thanks again for your help.
