it would be nice if the EQs would go even lower than -24db so that if Low/Mid/High are all on their lowest end nothing else would come through and the song is effectively silenced.
The same cutoff behaviour would be nice for the filter so it can be used to fade a track in or out.
…indeed. “Killable” EQs are a must these days and especially if you’re DJ’ing in electronic music genres.
This is an idea that’s 5 years old now and hasn’t got any traction from Algoriddims side. Why?
Might be that it’s a bit of work to copy the EQ curves from e.g. A&H, but it’s definitely worth it if Djay PRO (and of course Djay for the iPhone as well) wants to attract more PRO users. So what keeps you from upgrading the EQ section to a professional level?
And, yes, of course the filter has to be changed to a non-resonant one too!
@Lukas: thank you for your response and I’d love to see the kind of “A&H” type full-kill EQs and non-resonant filters. That would close the gap to professional DJ software solutions massively and then I’d also go for a Djay PRO subscription.
…I was more than happy to read “Improved Filter range and resonance” in your release notes of the 3.2.2 version of the IOS app. Now I tested it and… nothing changed. Really nothing (compared it on two devices, one with 3.2.2 and one with 3.2.1)!
What happened? Did the filter/res update slipped out of your release?
Again: filters without resonance (or better: adjustable resonance) and killable EQs are a must. Not only for “Pro” DJs!Â
Lukas You said something was getting worked on 3 years ago? Do the real employees of Algoriddim even look at these forums? This software has great features but the worst sound engine of all DJ software… do they even listen to music through their own software to compare how bad it is? The EQ is setup on all the wrong frequencies and the Filter is a disaster. Just give us control over the resonance. Put an option in the FX section ! And you want us to pay for the iPad version monthly when we can’t even get what we want? Most of us are still on the free loyalty promo, let’s see how many subscribers you have left when we have to pay for ignorance!!
The current one look like a lot of DJM tables where there remain a bit sound when they are all killed. I am used to that since on all DJM tables it is like that.
Multi EQ profiles exist on Mixvibes Cross, Traktor, VDJ (can setup each range) so that could be another powerfull feature.
In reality we’re dreaming if we think this is ever going to eventuate…
l asked for this over 4 years ago,
they put a man on the moon in less time!!
